Question about Garmin StreetPilot c340 GPS Receiver
StreetPilot c340 will not power on - even with soft reset
- I did a soft reset...still no power on
- Tried to charge by car charger (fuse works fine) and by USB on PC...still no luck
- The only thing that happens is when the garmin is connected to the PC via USB and I Hold the "Soft reset" button for 3-4 seconds, the computer gives a message of "USB Device not recognized"
  • 3 more comments
  • five40kix Jul 26, 2008
    Does this sound like a dead battery issue...or worse?
  • irishbutterf Jul 28, 2008
    I m having the same problems and my warranty was just up. On hold with garmin will post info of what they tell me....
    well, after being on hold with garmin for 32 minutes they want me to send them the unit back and will repair it at no cost. Try calling garmin I purchased mine on may 25th, 2007.
  • katwoman62 Sep 22, 2008
    street pilot c340 gps
  • b1moran Sep 27, 2008
    My Garmin c340 wont turn on at all. Doesnt look easy to take apart either... Its about a year old.
Well after being on hold with garmin for 32 minutes they told me to send them the unit back and will repair at no cost.
My unit was purchased on may 27th 2007.
Posted on Jul 28, 2008
Garmin Street pilot C340 has always worked. This morning it did not turn on. I relpaced the fuse in cord. Any other ideas?
Try charging it from the WALL charger. The battery inside the unit may not be too great. Try it - over night from the WALL charge -not the PC charger. 8de415c.jpg
May 04, 2010 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
My Garmin Street Pilot c340 does not turn on
try calling Garmin and ask their tech department for help or go to their web site and explain problem they should get back to you right away.
Oct 03, 2017 | Garmin StreetPilot c340 GPS Receiver
GPS StreetPilot c340 quit working
Plug charger in, and then reset it. Let it charge for awhile before tryng to use it though. It sounds like the battery is very very low. When it is plugged in it still will not operate unless the battery has some charge in it. I hope this helps.
Apr 18, 2009 | Garmin StreetPilot c340 GPS Receiver
StreetPilot c340 will not come on even when plugged in
I had this problem before, i called garmin and they told me that the charger cradle was not design properly so it sometimes doesnt charge...anyways...carefully remove the grey cover around touchscreen and there is a master reset which will set it back to worked for me...good luck!
Oct 13, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Gps not turning on
Have you tried charging it using the computer? This sometimes helps.
Feb 05, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin 340 streetpilot won't even turn on?
I had the same issue with mine during a trip. Probably needs to be reset. See page 31 of the users manual on Resetting your c340. Once I did this it worked fine.
Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
I had the same problem recently... What I did was open the front casing and hit the reset button under the cover, then it turned on while plugged into the car adapter.
Dec 29, 2006 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
162 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
