Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Black smoke My Harley has a little bit of Black Smoke come out of the Exhaust just when I start the bike. Can Somebody please tell me what it could possibly be. Thank You
Most harleys will exit black smoke on start up. a cause of this is when you first roll over the engine the cylinder will load with fuel but it will be too lean to fire but on the next roll over when cranking speed is up the mixture will be a little rich and when it lits off will exit the black smoke. also, do not roll the throttle at start up because the accelerator pump will dump a shot of fuel into the manifold. if the air filter was that clogged, you will have problems all over the rpm range and not just at start up. by the way black smoke is unburned fuel and blue smoke is oil. if you see blue/grey smoke it is a sign of low compression, unburned fuel and oil by-passing the control ring, usually disappears when cylinder comes up to temperature. come on pyrhyc, this is basic stuff. if you start blowing blue smoke, check the umbrella valves in the rocker box first, common problem.
Posted on Aug 27, 2008
    Genius:
  • 2,028 Answers
Change your air filter and clean the blow by tube that crosses the heads and connects to the back side of the air filter. If the tube or the air filter is clogged, then the oil that the blow by removes is going back into the cylinders, causing the black smoke. Also keep in mind that a Harley will blow a little black smoke upon starting as it ages, it's normal.
Posted on Aug 06, 2008
I HAVE A 2001 HARLEY DAVIDSON ROAD GLIDE ... IT PERIODICALLY BLOWS WHITE EXHAUST ... USUALLY WHEN I STOP AND ITS IDLEING
White smoke means water so there is an internal water leak into your combustion chambers causing the smoke. Possible head gasket starting to leak.... Blue smoke is oil and black is gas as far as the smoke emitting from the exhaust. Have you needed to fill the radiator lately? Good luck.
May 05, 2017 | Harley Davidson Motorcycles
Black smoke and oil from 89 pathfinder
Could be too much oil in the engine or bad valve seals
Nov 25, 2013 | Cars & Trucks
Exhaust smoke
check air fuel mix seems like bike is running rich
Sep 22, 2013 | Honda Motorcycles
Black smoke coming from exhaust occasionally.
Black smoke is indicative of carbon or incomplete combustion caused by either poor ignition (weak spark) or too much fuel (choke setting). Check out these areas.
Mar 31, 2017 | 2003 Suzuki VL 1500 Intruder LC
White smoke coming out of my yamaha 2008 r6 whenever i start the bike. why is the white smoke coming out ?
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. WHITE SMOKE on start-up can is usually caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers.
2. BLUE SMOKE on start-up is usually caused by failed valve seals. Smoke that is constant while riding is usually caused by valve to guide and piston ring clearances that have exceeded service wear limits.
3. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/205697-white-smoke-exhaust.html
White Smoke Coming Out My Exhaust Please Help
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 28, 2012 | 2008 Yamaha YZF-R6
Bike is smoking. Was not running for aprox 2+ years. Carburetor fixed and all o-rings replaced. Bike started and and is very heavy on fuel and is smoking. Please help
If it is black smoke you have not cleaned, adjusted the carbs correctly. If white smoke then you have oil entering the combustion chamber and or exhaust.
Nov 15, 2009 | 1993 Triumph Daytona 1200
2000 Volvo V70 2.5 TDI excessive black exhaust smoke
black smoke( too much gas)
blue smoke( burning too much oil)
white smoke( burning coolant)
Apr 20, 2009 | 1998 Volvo V70
Lands Phones Logo
652 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
