Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
I have a 24" Bosch diswasher - water does not drain
After the wash cycle the water does not drain. there is water at the bottom of the dishwasher.
  • muttjosie Aug 25, 2008
    I have a SHV 46 C13UC /40 Stainless steel Bosch dishwasher.. Just a year old... Smelled a rubber smell and water does not drain out during normal wash cycle
I have the same problem with my she58 water does not drain. only 4 months old and repair man replace 3 diff parts ...same thing happen. Bosch send another company to repair..replace parts by parts. not working....almost 5 months now I don't have dishwasher...i have to call almost everyday to Bosch..to fight for it....couple of days ago customer support told me with in 10 days somebody would call me for the replacement....i have to wait and be back if i don't have heart attack..to tell if they really would replace...gemtx
Posted on Aug 17, 2008
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
May 14, 2012 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Diswasher won't pump water out after cycle
it needs a new drain pump for around $65 dollars. the install will take close to $90-$120.
Apr 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Diswasher not draining
Soyben, you need to check to see if either the drain hose or syphon break at the sink is clogged. The drain motor on this model is not a bilge pump that will remove water from the base. Therefore Im leaning on a restriction somewhere. Other than that you may have to check for debris in the drain sump. Check these areas out first...Catriver...post back
Aug 27, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
418 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
