Question about Cell Phones
My phone is only showing a white screen.It wont react to commands like it should either.
  • 35 Answers
Well if u dropped the phone u may have to get it serviced. but if the phone just started to mess up, it may be a manufacturing defect and should be replaced immediately before warranty is void.
Posted on Jul 26, 2008
I phone wont turn on
Need a little more detail than this....what model iPhone? Is your battery charged? Have you tried plugging it into a computer running iTunes to see if it reacts? Is the screen showing anything, or is it just black?
Dec 29, 2012 | Apple iPhone Smartphone
There is a key combination to perform a hard reset for an LG KP500?
  1. Start by pressing Power button, device must be working to succeed this operation.
  2. Pressing Call key will open phone's Dialer.
  3. Type in this code into dialer. (Code: 1809#*500#)
  4. Factory reset operation needs to be confirmed by clicking green Call key.
hard reset for an LG KP500 Google Search
Jun 19, 2017 | LG KP500 Cell Phone
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
My phone t23 duo LCD problem. White and black blank screen shows but still respond to touch.
I have the same problem. touch screen still reacts to respond but nothing displays on the screen but all white.
Jul 12, 2011 | Cell Phones
My iphone shows only white screen when i try to power up
hi,
try this solution...
1. Put phone into Recovery mode (NOT DFU)
While the phone is off, hold down the Home button and immediatly plug it into your computer. Or else.
2. From a command prompt (Start>Run>"cmd"), change to the directory where you extracted irecovery, and enter irecovery -s followed by:
1. setenv boot-args 2
2. setenv auto-boot false
3. saveenv
4. /exit
Keep this window open for use later on!
3. Run greenpois0n - it will guide you to enter DFU mode, then it will stop on a white screen after you click "Jailbreak".
It should say "Jailbreak Complete!" and NOT "Jailbreak Failed!" next to the progressbar at the bottom.
4. Extract the iBSS from your custom PwnageTool image (firmware.ispw/Firmware /dfu/iBSS.BoardID.RELEASE.dfu) into your irecovery folder.
You can use WinRAR or another ZIP extractor to do this. IPSW files are really just ZIP files!
5. At a command prompt: irecovery -f iBSS
iBSS should be replaced with the name of the iBSS that you just extracted from the pwnagetool image - ie iBSS.n88ap.RELEASE.dfu
6. At a command prompt: irecovery -s
1. setenv boot-args 0
2. saveenv
3. go image decrypt 0x41000000
4. go jump 0x41000040
5. /exit
At the "go jump" point your device should appear to reboot. Whether it goes back to a white screen or shows the Connect to iTunes screen depends on the firmware image used.
7. Restore your PwnageTool cooked or CFW firmware from iTunes.
Feb 03, 2011 | Apple iPhone 3GS Black (16 GB)
My rumor got wet a few days ago it wont get off the hello screen what should i do
Hi,Phone is reacting to the water inside of it, that why it is free zed.
You where suppose to take the phone for service when it went into the water. It could have prevented it from showing hello on the screen. you will need to restore the phone by first servicing the phone and then flashing it.
Flashing the phone will restore by memory loss of the phone.
Use the site below to see more about flashing of phones.
Take care.
unlocktotalk.com/UnlockCodeInstructions.htm
May 20, 2010 | LG RUMOR Cellular Phone
My screen is white it wont show anything but i can
I believe your screen may have a bad connection to the handset, try flipping it many many times using more pressure then normal
Oct 12, 2009 | T-Mobile Sidekick ID Cellular Phone
Screen won't respond to touch
Put mailing tape across the screen then lift it off. I think that the sceens get stuck together and when you take the tape off it "unsticks them".
May 27, 2009 | LG AX830 Glimmer Cell Phone Car Charger
Frozen Camera and white screen/distorted image
im sorry i can thelp and i belive your phone company wont help either because your not really suppose to play with it. it voids your contract.
my solution - buy a new phone off ebay and active it online
Nov 27, 2007 | LG KG800 Cellular Phone
Cell Phones Logo
82 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
