Question about Canon P23-DHV Calculator
Ink replacement How do I change ink?
  • Anonymous Sep 22, 2008
    printing is very faint. seems to need ink
    Problem Solver:
  • 6 Answers
It takes a CP-13 ink roller. The cheapest I could find was a 5 roll set online at the Canon store. It is $16 with a $5.99 shipping and handling charge. They also charge sales tax. The rollers can be bought at many places including ebay. It's removed by pulling up on the right hand little tab part. The new one should snap right in. Be careful not to touch the ink section. The cartridge is the same for any P23-Dh machines it doesn't matter what Roman numeral one you have.
Posted on Oct 21, 2008
Trying to change ink cartridge on epson nx515 printer. how do I move the container out from under the printer to change it?
If your printer is out of ink, it will display the ink that you need to replace. Just open the lid and press the OK button.
If you want to replace an ink before it runs out, press the Setup button then go to Maintenance and press the OK button. Select "Ink Cartridge Replacement" or "Change Ink Cartridge", then press OK. You can now lift the lid then replace the ink.
Nov 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Warning:
Note:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do you change ink cartridgesfor the epson r300
Press Ink button;
Select Ink Cartridge Replacement
Press OK
changer cartridge
then press OK
And wait for initializing
Dec 18, 2009 | Epson Stylus Photo R300 InkJet Printer
I replaced the black ink and it keeps saying replace ink cartridge. I actually went ahead and changed the color as well even though it did not ask and it keeps saying replace cartridge. HELP! I am a...
Did you replace the ink cartridge with a new one, or did you refill an old one.
Some printers have a memory and can tell which ink cartridge is in them. This prevents them from easily being fooled into printing with refilled cartridges.
Another option is that you changed the ink cartridge without following the specific guidelines for replacement e.g. To replace the ink cartridge, select replace ink cartridge from the main menu, then open the printer panel when the light flashes X number of times.
You might also try unplugging the printer for a couple of minutes the reset it.
Oct 15, 2009 | Office Equipment & Supplies
Ink changing
Click HERE for the User's manual.
See page 34 on the manual to see how to replace the inks. There's also illustrations and explanations on how to get the ink chamber to the center so you can replace it.
Apr 14, 2009 | Office Equipment & Supplies
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Changing ink cartridge
OK button.
Hope this helps.
Aug 05, 2008 | Epson Stylus Photo R320 InkJet Printer
How do I change the ink in the canon ip4300 printer?
Go here. Type "change ink tank" in the search box and click on Search. Then click on the item that says "How do I replace or insert an ink tank". You will see instructions with animated graphics to assist you.
Apr 22, 2008 | Office Equipment & Supplies
Canon P23-DHV Calculator Logo
446 people viewed this question
old marine
old marine
