Windsheild wipers wont stop unless i take out the fuse while running. what is wrong and how can i cheaply fix the problem its an 88 gmc sierra and i spent 500 dollars on it with a new battery.
it look like low battery.. have voltage battery check then alternator if charging while running headlamp on are not white but kind of yellow. meaning alternator not charging
May want to look at replacing the wiper circuit board.It is located on the firewall adjacent to the wiper motor and has a some what square black cover with 3 torx screws and wireing harness pluged into the side.We had a truck that every time you washed it the wipers would stay on until it dryed out.You can try removing it and spaying it down with contact cleaner just watch the brease on the two contact tips.Well hope this helps.
replace the relay for the wiper motor... it's located either in the fuse panel under the dash or the fuse panel in the engine compartment near the battery
if you pull off the cover undeer your windsheild washers, there is an motor and a arm that conects the wipers together, that may have broken off, as your one works it wont be the motor
hi the contacts in the switch would appear to be faulty if you can get to the switch try spraying the switch with wd40 or simular as if you can spray the contacts it may clean them if you want abit more positive diagnostic while wipers are working disconnect the wires from the switch when they won,t turn off if they continue to work check out the relay yates210456
