Question about Garmin zumo 550 GPS Receiver
Garmin Zumo 550
Touch screen freeze up. I have re calibrated it . I have restored to Factory. I tried without any card in it. The touch pad is way off but the calibration does not help
I am sending it in for warranty repair.
Posted on Jul 27, 2008
The touch screen doesn't work with my finger tip, only when my nail touchs screen, also did the screen calibration, did not not help
It may be a resistive screen rather than a capacitive screen which is not as sesitive to touch. You may need to use a stylus as it may need slight pressure vs just touch if it is a resistive screen.
Apr 05, 2013 | Garmin zumo 550 GPS Receiver
It will not stay on it is fully charged
master reset: with the Zumo off, press andhold the lowest right corner of the touch screen while powering it on, keep the touch touch screen pressed until it says something like are you sure. then press yes and follow the onscreen instruction
Mar 03, 2011 | Garmin zumo 550 GPS Receiver
The touch screen is not working. I've tried the reset and re-calibrating but neither have helped. can the touch screen be replaced?
yes it can be replaced, quite cheaply too you just need to be very careful when removing the old one as it is glued to the lcd so there can be a risk of breaking the lcd. use a scalpel or craft blade to prise the touch screen up and gently score inbetween the two to remove it
Feb 27, 2011 | Garmin zumo 550 GPS Receiver
When I touch the screen it is not bring up the correct number or letter
Hold the power button down for about 1 minute and the calibration screen will come up.......follow the directions
Apr 05, 2010 | Garmin zumo 550 GPS Receiver
Garmin gps keyboard -- left upper corner fails to work when press ''A'' is C and others on left side are incorrect also. How do I fix?
Sounds like you need to recalibrate the screen. This can be done by following the steps below:
To Calibrate the Touch Screen on a zūmo®:
1. Turn the unit Off and make sure it is not attached to any outside power source.
2. Power the unit On, continue to hold the Power button for 1 minute. 3. A screen will display that says, Press dot in the lower left corner. 4. Release the Power button and touch the sequence of dots until your unit says Calibration complete.
Sep 19, 2009 | Garmin zumo 550 GPS Receiver
Touch screen is a little sluggish
Try cleaning house on it.
Also Try the Garmin web-updater Here to keep it running well.
You could wipe all data and start again,
Backup anything you want the Pc....
Hold bottom right of screen, keep pressing until it says,
Do you want to erase all data, erase it, select yes,
Re-register with Garmin, re-update,
Your good now,
Apr 16, 2009 | Garmin zumo 550 GPS Receiver
My touch screen has froze up & know matter what i do i can't the proble
Assuming that you cannot switch it off and on again, try removing the battery for a couple of minutes before re installing. Failing that a cold reboot my work ..... with the unit switch off press and hold the bottom right corner of the touch screen and the press the power button. The Zumo splash screen should appear....continue to hold the botton right corner until the reset default screen instrution appear and follow them. This has work in the passed.
If you have recently download a latest software via the Garmin web updater this can sometimes cause conflicts and you may need to re-install a prervious version. from the Garmin link attached.
Sep 07, 2008 | Garmin zumo 550 GPS Receiver
No road maps ( Zumo 550
Do you see a map, with street detail? Any SD card installed?
Tap the wrench symbol, tap mapping, tap about, any maps checked? if not, check the apropriate map and go back to the map screen
Jun 07, 2008 | Garmin zumo 550 GPS Receiver
Touch screen not working properly
I'm not familiar with the Zumo family of GPS from Garmin, but if they are similar enough to the StreetPilot, you should be able to recalibrate the screen. In the StreetPilot series, to recalibrate you turn the unit off. Press and hold the bottom right of the screen and turn the unit on. Keep pressing the screen until the calibration information begins. Try this, see if it works on the Zumos, too.
Mar 11, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
343 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
