Question about Gateway FPD1975 19" LCD Monitor
Monitor blinking on off, bought it at a garage sale  cannot get it to work on either of my computers
  • Anonymous May 01, 2009
    Monitor light blinks in yellow and on off continuous, no display in monitor
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Plz tell me,
you screen is blinking or a on of led.
Posted on Jul 27, 2008
I have a desktop computer that has been working fine. Now the monitor stays on for a few seconds and then turns off. I tried the computer with a TV and it worked fine but I now purchased another monitor at...
It sounds like your video adapter (probably on the motherboard) is failing, and you'll need to get another video adapter you can plug into one of the slots.
Aug 10, 2014 | Computers & Internet
No signal
Check cable connections. Check using a different monitor.
The only other possibility is that you're trying to drive it with a signal that is beyond the capability of the monitor. But the computer boot-up (BIOS) screen won't exceed the monitor's capability.
May 15, 2010 | Sharp LL 172A-B 17" LCD Monitor
I bought a mag innovision model 780 monitor at a garage sale to use with my ACER mini laptop. This monitor has a manufacture date of January 2003 - it did not come with a power supply. Where is the power...
With Most Mag monitors, the plug is a simple 3 prong on the bottom side of the monitor. Though it isn't proprietary, it isn't a common power plug either. Radio Shack does carry this type of cord. Just look on the bottom side of the monitor itself. the three round plug "thingy" is where the 110v plugs in straight from the wall. Best of Luck!
Feb 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Apple power macintosh 8500 video won't display
Could be either or both of two problems. One is signal routing: some monitors want synch on green, some want separate synch. The VGA adapters come in different types for each, and some adapters have switches on them to select your monitor type. You may need a different adapter. The other issue is resolutions and refresh. You have to tell your Mac to use a resolution that the monitor can accept. You may have to use software like SwitchRes to enable non-Apple resolutions.
Aug 16, 2009 | Apple Power Macintosh 8500 Mac Desktop
Garage sale purchase ...no instructions a few wires that's it
All you need to do is plug in the video cable into the back of your computer (VGA port) and plug the monitor into the wall. If the monitor doesn't turn on when plugged in, then the monitor is bad.
Apr 26, 2009 | Computers & Internet
Monitor blinking on off, bought it at a garage sale  cannot get it to work on either of my computers I have a FPD 1976W 19" Monitor and it blinks on and off but when I am on the internet it has never done...
hi im josh in cebu phils.may i help you? just try this stuff it will help you. Monitor Problems:
THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
- Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician.
COMPUTER BOOTS, BUT DISPLAYS “JUNK” ON THE SCREEN
- It may be that the display card is defective. Try a different card. If it works the first card may be bad.
- Try the suspected bad card on another computer. If it displays the same thing it is conclusive that the card is bad.
DISPLAY IS DIM, OVERLY BRIGHT, OR BLURRY, OR UNPLEASANT.DISPLAY IS OFF CENTER. LEFT OR RIGHT SIDE OF MONITOR IS OBSCURED.
- Try adjusting the control knobs located on either the front or back of the monitor. It maybe necessary o open the monitors casing to get the proper adjustment controls. In this case be very careful because there are high voltages in the monitor.
THE VIDEO DISPLAY FADES AND BRIGHTENS, OR IS WARY.
- The voltage may be fluctuating due to so many appliances or electric devices on he same branch circuit.
- Turn off other appliances and peripherals, such as printers, external modem, refrigerator, microwave oven, transformer, etc. and see if that solves the problem. If the problem persists, try swapping out the display cards. If changing the monitor solved the problem, repair or replace the monitor.
IMAGE IS NOT STRAIGHT ACROSS THE SCREEN
- If the monitor is still under warranty, bring it back to the dealer for adjustment. If the you want to do it your self, bare in mind that this is potentially dangerous procedure because it must be done while he monitor is on and there is very high voltages around the picture tube.
WARNING: THIS IS A DANGEROUS PROCEDURE!!!
- Open the monitor casing and loosen the clamp holding he coils around he picture tube. You can loosen them (usually there’s a wing nut) and a rotate the coil assembly until the picture strengthens.
good luck please vote
Mar 06, 2009 | Gateway FPD1976W LCD Monitor
My Dell Monitor on/off switch blinks green all of the time.
You need to open the monitor and check to se eif any of the capacitors on the power board are bad. Common problem for LCD monitors. The bad caps usually vent at the top (they will look bad compaired to a good capacitor).
If they look bad then they will need to be replaced. I've seen this in Dell monitors, so there's a good chance this will fix the monitor.
Take it apart, get the values on the sides of the bad caps in the power supply pcb. Buy new caps, and de-solder the old ones and replace them with the new ones. Don't forget to trim the leads afterwords.
Jan 01, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
How i registry my computer
Do you mean register the computer? If you bought it from a garage sale, chances are it's old and you will not benefit from registering it.
Jun 18, 2008 | HP Compaq d530 SFF PC Desktop
Gateway FPD1975 19" LCD Monitor Logo
331 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
