Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Screams My cb makes a loud high pitched scream. It happens about once or twice a month, sometimes when severe weather is in the area and sometimes not. It lasts about a full minute and even continues if I turn the unit off. I don't have control of the volume of the scream, it is very loud. Is this common with this model?, is it the weather alert?, and can I disable it?
Do you have weather bands on your cb ? you must turn it to the off position (weather bands) or you will here the test signal from
noaa . now you will not get weather alerts.
Posted on Aug 12, 2008
Squealing noise
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Here is Manual onlineManual online
Nov 04, 2013 | Baumatic Dishwashers
In severe cold weather my 04 coupe "screams" a
When you hear this scream, it is caused by the altenator working. The belt is loose. If you have a serpentine belt then the belt tensioner is weak. If the altenator has it's own belt , then there is an adjustment bolt or pulley to tighten the belt.
Feb 02, 2011 | 2004 Infiniti G35 Sport Coupe
91 S-10 it has a high pitch scream
It sounds like a worn or loose fan belt. It's slipping on the pulleys causing the screeching noise.
Nov 22, 2009 | 1991 Chevrolet S-10
Hi i have hust turned my laptop on and it is making a biig noise and it is not stopping it comes on when u turn it on what should i do
Are you getting a high pitch screaming or a grinding noise? The Fan on the heatsink sometimes getting clogged with dust and over time this can cause the computer to turn itself off. Dependant on a high pitch scream this could be a number of problems, memory modules loose or faulty?? Would need more info about the type of sound..
Nov 07, 2009 | Medion md40298 Notebook
MY HOME THEATRE AMP. SHUTS OFF ITSELF, AND SOMETIMES SCREAMS W/ N
First suggestion is to recheck all the connections
Rifaa
Nov 12, 2008 | GE GTD120 System
Sometimes screams a high pitched noise when turned on
the high pitch noise is from the HV. arcing acrss each other.
( the screen comes up at a pop).
I suggest get a better one. ( sorry! no domastic brand).
Oct 27, 2008 | RCA HD52W56 52" Rear Projection HDTV
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
101 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
