Sony STR-DE325 Receiver Logo
Posted on Feb 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am using my speakers connected via the front speakers panel on the back of the machine, I don't know if it matters but they are connected as left and right using "A". So, my left speaker is playing fine, but the right speaker is so weak that when I turn the volume all the way up it still sounds very low. My dad fixed this once but I don't remember how he did it...
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Feb 21, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2765908
Points
24828
I presume you have proven the channel is dead by trying multiple sources, swapping a different speaker onto it and that the balance control is NOT all the way to one side; headphones don't work either and we're down to proving it's dead before you take it in to a tech, right?
There is the slighest chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure. One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you
How can I connect Bose 901 (speakers) to Sony STR-dh 520?
If you're using them in front then connect them via 2 wire (16 gauge or 14 guage) speaker wires to the back of the Sony unit. They're labeled left / right (as you would see speakers from the normal vantage point.) and front or rear. Make sure you get the pos/neg connections right. These are collored red (pos)/ Black (neg) on the sony and I believe they're red/black on the back of the bose speakers as well.
tip
How to set up a seven-speaker home theater system
Set up a home theater
How to connect your speakers
In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
How to position surround-sound speakers and a subwoofer
To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
  • The 5.1-channel system has five satellite speakers and a subwoofer.
  • 6.1-channel systems have six satellites and a subwoofer.
  • And 7.1-channel systems have seven satellites and a subwoofer.
Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
Connect your DVD player to your A/V receiver--digitally
To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
How to operat speaker
Please specify how exactly you're trying to make them work, what machine you're trying to make them work with, and what kind of connection your speakers are using.
General info:
Speakers usually get connected via 3,5 mm plug into the green round socket in the back or front of your computer. In Windows, if your speakers are properly connected and set up, right click on the sound pictogram in your taskbar and choose "Playback devices". Set your speakers to be the default playback device by left-clicking on the preferred device of your choise and clicking the button "Set default" below.
Don't have sound
first of all did you plug your speakers into the green connection in your printer.. are your speakers on and the volume on your speakers turned on ?? I know this sounds stupid check these things first. then go into your control panel and choose sound and make sure the speakers are not on mute and turned up via the computer. sometimes there will be a speaker icon down where the time is on the left side on teh start bar
15helpful
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • 0helpful
    All the speakers including the sub do no have any sound coming off. The only speakers that have sound coming from them are the very last ones in the back seat. How can I fix this?
    Check the wiring of the speaker that don't work, it might have been disconnected or the wires are cut.
    Look at the wires inside the door panel, which the front speaker is located, the wires leading to it might have disconnected via door panel wire harness inlet. You could see the wires at or near the front door pillar hinges.
    If the wire is cut off, strip the wire and join them together, wire color should be connected with the same color. After that insulate them by using electrical/plastic tape.
    Your local technician can repair it.
    Hope that helps you out.
    Thanks for using Fixya!
    I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
    To get "surround" sound, when you face the computer, you will have:
    * 2 front speakers, one immediately on each side of the computer
    * 2 side speakers, one on each side of your head
    * 2 rear speakers, one behind each side of your head
    Thus, when the sound is of a jet-plane coming towards your face,
    you'll first hear the sound in the front speakers,
    then in the side speakers,
    and finally in the rear speakers,
    to produce a sound-effect of the jet passing over your head, and going "behind" you.
    Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
    For side speakers, one speaker will connect to the LEFT-side-audio-output port,
    and one speaker will connect to the RIGHT-side-audio-output port.
    For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
    and one speaker will connect to the RIGHT-rear-audio-output port.
    1helpful
    2answers
    How to connect new HDTV to old stereo JBL speakers via TX-860 Onk
    Depends on the kind of plyg in you have at the back of your stereo...
    most strreo has phone, aux, tuner ,e.t.c..
    If yours has any of this good, just plug your red and white audio out cable in any of this element listed above, then go to the front of your stereo and activate the particular element you plug into and increase your volume.
    You will definitely here a sound.
    1helpful
    2answers
    The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
    The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
    This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
    Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
    2 ... ... ... 14
    1 ... .. ... 13
    The pinouts are:
    1 Mic in/center
    2 Ground
    3 Mic power/Bass
    4 Audio power
    5 Right line out/Speaker out Right
    6 Right line out/Speaker out Right
    7 Reserved
    8 Key
    9 Left line out/Speaker out Left
    10 Left line out/Speaker out Left
    11 Right line in/Rear speaker Right
    12 Right line in/Rear speaker Right
    13 Left line in/Rear speaker Left
    14 Left line in/Rear speaker Left
    2helpful
    5.1 Surround Sound Cutting Out
    HI,
    Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
    only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    John
    John
    ZJ Limited
    ZJ Limited
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
