Question about Olympus FE-280 Digital Camera
Camera doesn't turn on-battery recharge prob?
My camera has been great for 8 months then last week I recharged the battery and the red light on the recharger started to flash rather than turn off (as it usually does when the battery is fully charged) and now when i put the battery into my camera nothing happens- it won't even turn on.
  • breejc Aug 04, 2008
    The problem I 'm having has nothing to do with the lens. Its the battery and recharger. I think this solution is for the sand in the lens problem, perhaps you have accidentally given your solution to the wrong person. Thanks anyway. My camera was still under 1 year old and so still in warranty so I'v sent it back to be fixed or replaced.
Okayy well when it came out the first time i Grabbed the Lens and held it till the camera turned off and the lens stayed out i blew on it and i turned it on and it worked =)
Posted on Aug 01, 2008
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
My Kodak Easyshare M575 digital camera will not turn on. It turns on okay without the battery while plugged to an electrical outlet. I've tried charging the battery and that doesn't work. The...
If unused for any length of time, rechargeable batteries lose their ability to retain a charge. Try it with a brand new, fully-charged battery. FWIW, I recharge all my camera and flashgun batteries monthly.
Nov 07, 2017 | Kodak EasyShare M575 Digital Camera
My Fuji Finepix S5800 tells me my brand new batteries are flat.
It sounds like you have bad batteries. I have had rechargeables that have suddenly done the same thing. I have learned that buying really cheap ones doesn't work out. If you buy a good branded set, I think you will find that they are much better. :)
Jul 17, 2010 | Fuji Finepix S5800 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Toshiba Camileo h20 battery problem Toshiba Camileo H20 camcorder bought in July O9 Worked fine on 2 week holiday and have recharged the battery 2 or 3 times since. Latterly battery charge didn't last very...
It's eight years old now, and if as you say it has had intermittent use, then the battery will probably have died unless charged at last once a month.
Mar 27, 2017 | Toshiba Video Cameras
no problem. your rechargable is not strong enough for this camera. i use rayovac rechargeable from wal-mart and the batteries have to charge for two full days and make sure the light on the charger is off before removing the batteries from the charger. then put them in the camera and it will work perfectly. your batteries aren't strong enough for the camera. go out and get some energizers made just for digitals. they last forever but, they'll do until you get your rayovac rechargeable recharged. and coming right out of the pack they are not charged give it 48 hours and they'll last weeks.
Sep 18, 2008 | Samsung Digimax D53 Digital Camera
Batteries are Depleted
A camera rep told me that use about 2500mi (?) batteries instead of the 900 I was using otherwise the batteries will be depleted with just one picture. Digital cameras or any other digital piece of equipment needs the extra power. Make sure that your charger will charge the 2500 power ones fully.
Dec 17, 2007 | HP Photosmart M407 Digital Camera
Same problem
your batteries are dead.
Oct 27, 2007 | Samsung Digimax S500 Digital Camera
Drained Batteries
I use professional $70k cameras for work and it's the same type of thing. If you're not using it, take the batteries out. With my A75 I have some energizer 2200mpa rechargeable AA's and the seem to last about a month or so. If I happen to be "cranking" through pictures though (upwards of 300-500) in one sitting, it will suck them dry. The rechargeable batteries last longer than the Alkalines. I was heistant with the rechargeables but for $20 I picked up a 15 minute charger and the 2200mpa AA's, now I recommend them to everyone with a digital camera. Digital cameras eat Alkaline batteries in a hurry.
Aug 31, 2005 | Canon PowerShot A75 Digital Camera
Olympus FE-280 Digital Camera Logo
155 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
