Question about McCulloch MC1275 Steam Vacuum
Steam cleaning an oil spot on driveway
What brush or attachment do i use to clean oil spots off my driveway
Hello gktweets,
Cleaning oil stains off of your driveway will require the right "products". However, if the oil stains are a heavy buildup then you will definately need to steamclean them off first.
What you will need to do is apply a sodium hydroxide based degreasing product (basically most types of degreasers) to the oil stains and let the product sit on the stains for a few days allowing for the degreaser to completely dry.
Then you will want to use a "hot" water pressure washer to steamclean the oil stains off. If you do not have a "hot" pressure washer then a cold water unit will work too just not as effectively.
If you do not have access to a pressure washer at all you should re-coat the oil stains with your degreasing product then scrub with a broom and rinse with a garden hose simultaneously.
After your driveway is completey dry and the oil stains are still minimally present you can apply a dry product known as Bio-Dry. They have videos posted up on you tube as how to purchase and apply the product.
This product will go to work on the leftover stain and will work "over-time" as far as lifting the stain out of your driveway.
You can see before and after pictures here at this site: http://www.DrivewaySteamCleaning.com
Feel free to leave any comments on the site as well, they are much appreciated.
Hope this information helps you.
Posted on Dec 14, 2008
I have a hoover F5853-900 steam cleaner.Everytime i lift it up the brushes turn but when they are on the carpet they quit.I got told that this model does not have a belt.I really love this steam clean
The brushes are turned by a motor. No belt. It's possible the gears on the brushes have a flat spot on them which would stop them from turning under a load.
Dec 06, 2014 | Hoover Vacuums
Clean bissell spot bot brush
NONE of these answers apply to the question! The asker referred to the Bissell SPOTBOT, which doesn't have a push handle. I'd like to know how to remove the brush myself. I know how to remove the components but haven't been able to figure out how to remove the mechanism.
Mar 12, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
What is causing a slight burning rubber smell when running the vacuum?
If this is a sweeper model with a rotating brush, remove the brush assembly. Clean and oil (3-1oil or similar) the bearings on the ends of the brush. They are usually full of string, hair, and thread which binds the brush. Check the belt for burn spots or other damage. Hope this helps!
Oct 04, 2010 | Vacuums
Cleaning spots on carpet my pet throws up on carpet
Robert, I take care of that problem two ways. First I take a very wet cotton towel and put it in the microwave for about 1 minute. After that time I remove it while wearing a GOOD pair of gloves, as you are dealing with steam. Go to the spot and rub the heck out of it with the cloth. You may have to repeat, but do NOT forget the gloves. Also, there is a spray bottle product of a cleaner called Awsome. I find it helps clean these spots as well.
Aug 27, 2010 | Vacuums
Need instructions for filling the Hoover Steam Vac Spot with cleaning solutions
Hi There,
Here's a link to the owners manual for your Hoover F5505 Steam Cleaner that will explain step by step how you can add water & cleaning solutions and carpet shampoo. I hope that this was helpful to you. If it did help you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Hoover F5505 SteamVac Spot Vacuum Product Manual:
http://www.hoover.com/pdfs/manuals/F5505.pdf
Thank you, this is really appreciated.
Chris J.
GoVacuum.com
Apr 06, 2010 | Hoover F5505 SteamVac Spot Vacuum
Spot Bot leaking water from reservoir through brushes
make sure that your collection tank is empty and correctly attached. If it is full, it will shoot water on the spot, but not **** it up several times in the cleaning process leaving a large wet puddle bigger than the original spot.
Mar 16, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
The cleaning solution on my bissell spot bot is not being pumped through....on the stationary mode or the manuel hand held mode with the brush attachment
I had the same problem, and found that the culprit was that the small filter element. about the size of a dime, that sits arount the nozzle activator (pin that depresses the clean water nozzel) was clogged with "gunk", and prevented cleaning solution from flowing into the unit.. It is easy to remove with a pair of tweezers or needle nose pliars.. rise it under water and reseat in the unit. You shoudl be aboe to perform the whole process in under a minute. This has happend to me several times... and am surprised the filter is not mentioned in the manual.
Nov 07, 2009 | Bissell 12005 Spot Bot Handheld Vacuum
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
McCulloch MC1275 Steam Vacuum Logo
223 people viewed this question
Top McCulloch Vacuums Experts
Bill Boyd
Terry Weaver
Terry Weaver
Are you a McCulloch Vacuum Expert? Answer questions, earn points and help others
