Question about HP Pavilion dv9000z Notebook
Upgrading my laptop processor
I bought a computer about a year ago, but it is running really slow. Is it a matter of needing more RAM (it has 1GB) or getting a new processor (it has 1.8 GHz)?
    Genius:
  • 2,028 Answers
You just need to clean it up a bit. Also, if you're using Norton, it will slow the computer considerably. Go into the system tools in the accessories, and do a disc defrag and clean up. Then go into add and remove programs, and remove any unused or unnecessary programs, especially any programs with the word Doctor in them that you may have inadvertently picked up on the web. Now go to filehippo.com and download CCleaner. The CCleaner will clean up the registry and other areas of the computer. Run both the registry and regular cleaners. And finally, if you have Norton, completely remove it and down load AVG from File Hippo. AVG is a much better antivirus and doesn't use the amount of resources Norton does, therefore allowing your computer to run faster. Do this and let me know of the improvement.
Posted on Jul 26, 2008
    Sergeant:
  • 310 Answers
Hey, your best bet is upgrading the ram, if its ddr 2 will cost about 25-30 pounds for a extra gb, which will make it run a bit smoother. noone ever upgrades processors on laptops as your usually restricted to what u can uppgrade it too or costs too much.
i would suggest the memory upgrade...
if i can help anymore just ask..
All the best
John
I am having celeron processor with 256 RAM and 40GB HDD Can i install Windows 7 or Vista over this processor
Well, Vista and Windows 7 require at least 1GB of system RAM to run, If I were you I'd think about upgrading with more memory. Otherwise you will experience a very slow PC, the RAM problem will then slow down your CPU and you'll end up with a big mess.
Nov 13, 2010 | Toshiba Celeron M, 1.4 GHz 330 (SL6N6)...
Do this model supporsts win xp service pack 2
Hi.
This unit has a Pentium 4 2GHz single core processor, and does support Windows XP SP2.
The standard memory installed on this unit was 256KB RAM, in order to run XP efficently you will need to upgrade the RAM. I suggest upgrading RAM to the maximum amount allowed of 2 GB RAM.
To upgrade the RAM to 2 GB you will need 2 modules of 1GB PC2100 184 pin DIMM ECC each.
Micron 1GB DDR RAM PC-2100 ECC
May 25, 2010 | IBM eserver xSeries 205 8480
I have a ACEer 5315 model no ICL50 running Windows Vista. To say Vista is **** is an understatement. I want to switch to Windows 7 but guess I will need a lot more RAM for this. Can I upgrade Ram on this...
I recommend that you switch to Windows 7 without upgrading your RAM. Windows 7 is a lot faster, better and uses less RAM than Vista. Recommended RAM for running Windows 7 is 1GB but I have installed them on a Centrino 1.5GHz with 768Mb of RAM and they run perfectly.
So make the upgrade to Windows 7 anyway and if you feel that you need more power then you can get more RAM.
Also, download Windows 7 upgrade advisor to check if your pc is compatible. Download upgrade advisor here.
Feb 06, 2010 | Acer Aspire 5315 Notebook
I have pentinum4 intel(R) celeron processor 1.3 GHZ processor. I want to increase the speed of my processor without any hardware change. I have 40 GB HD & 512MB with windows XP RAM.plz help
you cannot change the speed of your processor unless your processor supports overclocking. however your processor does not support that.
if your computer is running slow try upgrading the RAM to 1GB.
also check to see whether you have unwanted applications running in the background
Jan 25, 2010 | Intel Celeron D 335, 2.8 GHz Processor
How to stop when i use the scroll bar the page from fluttering
Check to see if you have correct graphics driver installed- if you do its because your processor is slow OR your graphics card sucks. IF you are using an on-board graphics card (built into motherboard) you might consider upgrading it to a add-on graphics card.
How much RAM do you have? anything less than 1GB should be upgraded to atleast 1GB total RAM.
Last you also should run a general clean and remove ad/ware & spy/ware as well as go over start up programs that run in background- minimize the overhead your computer needs to just run to improve overall speed. (less programs running in background)
Aug 06, 2009 | eMachines EL1210-11 PC Desktop
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Slow laptop dv 9208 w vista
If you're having Vista, you will need 1gb RAM minimum. Vista is resource intensive, concentrated more on graphics, and a lot of Hardware compatibility issues. Windows XP is fine and better as of now which runs great with 1GB of ram and a pretty processor of 2.0 ghz ...If you think of speeding up ur lappy better go for XP .increasing ur RAM will increase the number of apps that you can run productively at a time.
Mar 28, 2009 | HP Pavilion dv9000z Notebook
Slow boot up and slow performance
you have 512mb of ram, firstly i recommend upgrading to atleast 1GB of ram especially if using Vista.
You may have a virus, assuming you have got an antivirus programme, run it, if not click the link below for AVG 8 Free
http://free.avg.com/ww.download?prd=afe
Also clean your system of old temp and registry files using Ccleaner, again free, click link below
http://www.filehippo.com/download_ccleaner/
Aug 23, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
When you're running an average load, start Task Manager and view the performance tab. If the amount of free RAM is low, then definately upgrade your RAM. Plus, nowadays it's really cheap to upgrade ram.
As far as upgrading your processor, that can get a little tricky and expensive.
Also, what do you mainly use your computer for, and what operating system do you use?
Jul 26, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Upgrading processor on an iBuddie A900?
i have the same model with 512 ram and no difference with the video. Its the 133 front bus is just too slow for todays video speed. Adobe flash keeps upgrading for the faster computers and outdates the older machines. What i did with my I-Buddie was to take XP off, it weighs it down with all the processing going on in the background. I put Ubuntu on it and WoW! speed is way up again. Video is watchable much improved over XP.
Mar 02, 2008 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
88 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
