Question about HP Photosmart 2610 All-In-One InkJet Printer
Power adapter barrel connector
This unit uses a very non-standard barrel connector to connect the 31VDC power adapter to it. Does anyone know where to get a replacement or at least its manufacturer and type?
  • 398 Answers
Check ebay for a repacement unit, I have gotten several power units out there.
Posted on Aug 07, 2008
Hiya, does anyone know where i can get a charger for a R M z91fr laptop ??
If you can identify what the battery / laptop power requirements are, then you can buy replacement 'universal' laptop power supply / charger units which come with a selection of different standard connectors to plug the charger into the laptop.
Amazon sell a Sumvision Universal Laptop AC Charger Adapter which is available in different power output wattages (95V 120W). - you just need to select the correct DC output voltage by a switch selector and the correct connector for your laptop.
Jan 01, 2012 | Computers & Internet
I have a panasonic dvd home theater sound system SA-HT930, and the dvd player, is broke can do nothing with it, need a new one but the plug between the ampli and the dvd wont fit on any new dvd theater...
Believe it or not there is a seller on eBay who offers a one-price fixit solution for your unit for $100.
That aside, these types of systems are designed as a package to be used as a unit. Otherwise they might have standard connectors. Another closely-related Panasonic SA-HT system might work for you but I doubt anyone manufactures anyhting to adapt non-standard speakers to standard electronics.
They actually say on page 9 of the manual:
"Use only supplied speakers
Using other speakers can damage the unit, and sound quality will
be negatively affected.
I would interpret that to mean 'use these speakers only with similar Panasonic electronics'.
Jan 15, 2011 | Panasonic sa-ht930 Home Theater Audio...
I have a hp pavilion dv7 and the power socket has come a lose i need to know which wire goes where.....
The DC Power Jack that the AC adapter (Charger) plugs into?
Look into the DC Power Jack with a magnifying glass and light you'll see it's a center pin surrounded by a barrel. Barrel has an inside and an outside.
1) Center pin. Gold and buried down in the plastic. Connected to WHITE wire at motherboard connector.
2) Inside barrel has 4 Brass fingers.
Orient the laptop so the LED is at 12 o'clock and you'll see fingers at 12, 3, 6 and 9 o'clock.
These fingers carry the + 19 volt power to computer.
The ones at 6 and 9 o'clock do, Noon and 3 are not connected.
+19 Volt power arrives at motherboard connector on RED wire.
3. Outside barrel has six brass fingers, at 2, 3, 4, 8, 9 and 10 o'clock.
2, 3, and 4 are not used,
2, 8, 9 and 10 are the power return (common, or ground) to computer.
It arrives at motherboard on BLACK wire.
4. LED is connected to YELLOW wire and controlled by computer.
Other side of LED is jumpered to a Black wire,(Ground), outside barrel 8, 9, and 10 o'clock.
From > analog posted in an HP Support Forum.
Nov 12, 2010 | HP Pavilion dv1000 Notebook
LOST POWER CABLE.What type is it and whre dose it hook up?
Your printer takes a 31VDC 1400 ma power adapter.
Take a look at the Setup Guide:
Zoom in on Step 7. It shows where the power supply connects and also shows the requirements.
I found an online store that stocks the P.S. You can see it at:,Printer,Part,09504340.aspx
Thanks for using Fixya.
Jul 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I need an Adapter Hp 0950-4340 with cord.
You can go to HP's part page (here), fill in the part number (0950-4340) and order it directly from them.
This way you make sure that you get the right part for your printer.
If you want to look at other stores, make sure you get an AC/DC converter with the correct specs:
  • Input: 120VAC/220VAC, 50/60Hz
  • Output: 31VDC, 1.45A
The power cable is a standard 3-pole household power cable.
If you have any more questions, come back here and let me know - I'm happy to help.
Mar 13, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Polycom soundstation Ex - no dial tone
Someone in our office recently damaged the RJ-45 cable for our Polycom Soundstation. Because the jack was damaged I could not determine the order of the cables. After a call to polycom, we found the pinout information we needed - so I thought I would share, in case anyone else finds themselves in a similar situation:
With the RJ-45 prong pointing down the wires, from left to right are:
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Then Crimp and test. I got this information directly from Polycom for use with the Polycom Soundstation. This information was not easy to get. They originally told me they could not provide the information and I would have to buy a power adapter. This is not true, just trim the cable and follow the above instructions.
Sep 14, 2007 | Polycom PCY220016000001 SoundStation2...
What is the voltage, current, and polarity of the power supply for the SC-D23?
You should use the original Samsung supply since it is a switching power supply capable of supplying the needed current to operate the onboard charging circuit. Many customers have tried to go with generic supplies and it opens the inline chemical fuse due to the unit drawing heavy current during battery charging. Hope this helps. Joe Weibel Custom Electronics Memphis, TN 38133 (
Feb 12, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Need AC/DC adapter for monitor!
Hi inkedpandora, This one should work for you it's the same voltage and amperage as your unit. 19VDC 3.16A Any standard power cable from an old printer or computer will work with one of those PS's. The only thing you need to check before you buy is the polarity of the barrel connector. I looked on the net but could not find out that info so look at the jack where the power plugs into the monitor. You might see a little diagram showing a + and - signs. If the line coming off the + sign goes to the semi-circle than the barrel is positive and if the - goes to the SC the barrel is negative. Ask them before you buy which way that one is. As long as they are the same you will be able to use that PS. Good Luck, Dude
Nov 22, 2006 | Liquid Video A170E101 Monitor
HP Photosmart 2610 All-In-One InkJet Printer Logo
44 people viewed this question
Ben Johnson
