Question about Sony VAIO PCG-K35 Notebook
Upgraded harddrive on dell inspirion600m won't install drivers from dell cd
  1. cant install drivers from cd does not see cd/dvd drive
  2. i have added other programs from cds it worked fine
  3. have all on computer except 6 drivers
  • 2,028 Answers
Hello to all experts out here, i have this problem.i have an 80Gbts harddrive in my PC. and i want to add 2 harddrives of 40Gbts each. i have tried to do this by my self but i have this diffault. i...
Try these things,
Keep the main, original hard drive pin selected to "master", make sure the original hard drive is connected to the motherboard at the default connection.
IDE's it should be the last connector on the cord and not shared with the cd/dvd rom cord.
Sata's it should be the number "one" connector on the motherboard. The board is typically labeled and with numbers.
The new hard drives you should try putting them into "cable select" since you said setting them to "slave" doesnt work. It's a good idea to just go into bios to make sure those connectors are enabled. Some desktop bios are set to off or disabled.
Do you have a CD/DVD player? Sometimes I have seen they can interfere with adding hard drives. Why not remove it for the time being just to see if it works.
Aug 11, 2011 | Dell Computers & Internet
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
I want to install a seond hard drive in computer
can you please open up the CPU and check one thing? Is there any Free port in this cable? One end will be connected to the motherboard and two others to (1)CD/DVD rom and (2) Hard drive.
If there is free, surely you can add one. Please then look for a place where you can place your (ATA not the sata one) harddrive.
Apr 05, 2009 | Dell Dimension 4300S (Refurbished)...
Driver compatibility problems with dvd/cd drive dell 5160
You have given very little information regarding the actual driver, I do know that there was an issue with the original Roxio DLA.
You can uninstall the DLA or Drag to Disc feature in programs and features, or install the upgrade patch as per this dell link
Mar 24, 2009 | Dell Inspiron 5160 Notebook
Vista ultimate does not pick up dvd rom
how did you use it? where you using your dvd rom when you were still in vista basic then upgraded it to vista ultimate? if so, probably you havent installed the drivers for your dvd rom after upgrading to ultimate.
Feb 06, 2009 | Sony Optiarc AD-7170S Burner
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Swaping hdd
You have half a dozen reasons why this will not work. The Operating system (XP) does not recognise the different hardware, the Bios doesn't recognise the MBR (the file structure of the harddrive) and you have all the wrong hardware drivers installed.
There is a way to do this if you have the original XP installation disk, install the harddrive, put the XP installation disk in the CD/DVD drive and set the machine to boot from the CD/DVD first. When the machine boots up and goes to install XP follow the instructions as if you are doing a fresh install, when SetUp attempts to format the harddrive it will discover you already have a version of XP installed and will give you the option to repair it, go ahead with the repair and MAYBE SetUp will be able to see and install the correct hardware drivers. If not you are looking at Slaving the harddrive, saving your personal files and then formatting the harddrive and reinstalling XP fresh.
Oct 31, 2008 | Dell OptiPlex GX110 PC Desktop
Hp-Compaq d530 Cd/Dvd bootup problem...
Go to control panel/system and uninstall your drives in question. Than from "action" tab, scan for changes. This will reinstall the drivers.
Dec 06, 2007 | HP Compaq Business d530 Small Form Factor...
Sony VAIO PCG-K35 Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
