The HTC Touch does that all the time.
All you need to do is hold down the Send and End Call buttons down firmly and push the stylus up in the little hole near the usb port (Reset Button) and wait till the screen says that the phone is going to format and all data will be lost press the soft key to continue. Then when it says that press the center button and it will show Fat formatting and Rom formatting. This will erase all data on your touch so make sure you back up.
After turn on the phone and go through the set up and it should be perfectly ok.
You can do this for two reasons.
1. To reset the phone locks.
2. To repair the touch screen if it stops working.
Hope this helps. Enjoy
SOURCE: Forgot password
Good Day,
Have you tried the default code?
By default the code is the last four digits of the phone number assigned to the phone. However if the code was changed there is no way to retrive it other than taking it to a tech and having the firmware reset.
Good Luck
Hope this helps
SOURCE: how to unlock phone,when forgot password
hit restore factory setting and the old password is either 1234 or the last 4 of your phone number
SOURCE: i have forgot my phone password and i want to
if its not 12345 then it would need to go to a phone shop to have the code reset.
SOURCE: forgot password
http://nfader.su/index.php Give your imei number there. If you don't have your imei number call *#06# from your mobile. You will get a master security code. With this you can reset your password. Try this.
SOURCE: forgot the phone lock password ..
Hi,please dial this code on your phone, *#7370# code.This is a hard reset code,
Thanks and take care
we tried to unlock the phone didn't work, tried calling verizon didn't work so we are here
plz help i forgot my password????
i forgot my password to unlock my phone how can i unlock it?
unlock the g1
i have a HTC touch pro .
i forgot my password and it wont let me reset it
When I turn off my phone, it goes back to the same thing
HELP =(
i have a htc from unicel i got distracted and dont know what i set my password as help plz
