Question about Kenmore Elite HE4 Electric Dryer
Rattling in Kenmore pump
Hi, did you ever figure out what caused the rattle in your pump? I have the same issue. Hose line and filter are clear, but the pump rattles and water will not drain at the end. Can you respond to matt_procter@yahoo.com?
thx,
Matt
  • 116 Answers
Repl/ pump rattling noise is broken impeller in pump reason for no drain and spin
Posted on Nov 30, 2008
Portable air conditioner rattling
not sure i use mine without exhaust hose
Feb 21, 2014 | Amana AP095R Portable Air Conditioner
My dishwasher won't drain and there is a rattling noise in the door. I don't know if I should just get a new one as the repairman costs are high. I did start a cyle over and more water went in but...
there is a drain pump system on the machine could be clogged, also if the drain hose is not installed up and over the unit it will cause issues with drainage. as for the rattling noise you probably have either pieces of broken glass rolling around under the basket.if you are a do it your self-er its always fun to explore.if not the cost of repair would be the cost of a new install. don't waste your money.
Jun 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Washer is rattling like there is coins. checked the drain pipe and cleaned out but still making noise. gives a F-21 or Fd
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it.
Hope this helps... Please post back if you need more information. Daniel
Mar 26, 2011 | Kenmore HE2 Plus Front Load Washer
The washer started making a noise about a month ago, kind of like change rattling in the bottom of the machine. Today the machine leaked water all over the laundry room and down the hall. It didn't come...
sounds like the water pump, is leaking or the rubber hose from the drum to the pump. its very hard for money to get thru the filter holes, of the drum to the pump
Dec 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore oasis, when it's trying to drain, it sounds like something is rattling, like a coin, or metal button. I have to **** on the hose, (believe it or not), to get it to drain a lot of the...
Something is in the impellor of the pump.
Remove the hose to retrieve the item before it damages the pump impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 27, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore washer elite top load makes nosise when spining.
If it also tends to walk around, there are pads under tub supports that tend to wear out in this model. They are easily replaced.
Sep 04, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F02 whirlpool washer
HI, check the descriptions below to address this issue.
F02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jul 08, 2009 | Whirlpool Washing Machines
Washing machine makes a loud rattling sound
Hi.k.
Even though you have cleaned filter, there could still be something in the pump, you need to remove the pump and check there is nothing in it.
Hope this helps.
Good luck.
Please leave feedback
Nov 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer making a weird noise
I didn't get to answer this but It makes "cents" to me.
Sep 09, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
89 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
