Question about Compaq Presario Notebook
Won't boot up
When I go to turn on my laptop it trys to boot up but immediately stops and you hear a clicking sound and the key to turn on the laptop starts blinking
    Champion:
  • 258 Answers
Your hard-drive might not working or boot sector has been altered by VIRUS.
Posted on Jul 29, 2008
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Engine starts but stops immediately
it could be the main ignition relay. do you hear a click when you turn the key coming from the dash area ?
Oct 26, 2013 | Toyota Land Cruiser Cars & Trucks
When open my macbook air it take command automatically & when i click in the upper maneuver it take command continuously non-stoply & create a sound
Hi
hope you have fixed the problem by now.
If not try resetting the "p-ram"
Turn on your Mac and immediately press and hold the Option-Command-P-R keys. You must press the keys before the gray screen appears. Continue to hold the keys until the computer restarts, and you hear the startup sound a second time.
Hope this helps
Sep 05, 2013 | Computers & Internet
Turns over but won't start I just shut it off 3 hours prior
HHMMM sounds like the ignition module has failed ,classic symptoms running ,stop outside shop or work and it will not start .classic ,unless the chip has dropped out of the key ?? laugh as you may but yes seen it happen many a time with ford keys
Dec 02, 2012 | 2007 Ford E-350 Super Duty Length XLT
Acer MS2211 won't boot. Starts and beeps 2 times. Trys twice then turns off.
take out the memory sticks and replace them and try again.
Nov 16, 2012 | Computers & Internet
I have dell inspiron mini 1012 , when i turned it on booting it works then after 10 min it freeze, so i turned it off and tried to power on it worked but it didn't find the operating system, i tri
It sounds like your system might be running hot. Do you hear the fan running? If so it will turn on after it has cooled off, but once it gets hot it will turn off. If you immediately try to turn it back on, it won't work until the system has cooled off.
Laptops overheat because of the following problems:
1. Dust has clogged the Fans, Vents, CPU & Heat Sink Area
2. The FAN has stopped working
3. The Thermal Paste around the CPU and HeatSink has either dried up or is too thin to keep the system cool.
Try a can of compressed air and blow out the areas you can get to around the vents. You'll have to take the laptop apart to get to the Fan, CPU and Heatsink
Mar 30, 2012 | Dell Inspiron Mini 1012 Netbook...
Describe your HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook Problem it won't boot up, it lights up but nothing else
Does it make a beeping sound when you turn it on? If it does try this:
Turn it off and take the battery out for about 2 minutes. Put the battery back in and press the power button to turn on. Immediately tap the F8 key on your keyboard. This will bring you to the advanced boot options. Choose last known good configuration.
If that doesn't work you may also try choosing system restore in the advanced boot options and follow the instructions. Note that a system restore brings the computer setting back to a previous restore point.
I hope this helps.
Cheers,
Sep 04, 2011 | HP Pavilion dv9000z Notebook
STUCK ON START PAGE,CAN'T GET TO DESKTOP
Most likely a Windows software problem. Could be virus caused. Try restarting the laptop and immediately start tapping the f8 key until you see a screen with several boot options.Use the arrow key to select "boot using last known good configuration". If that works, you're done. If not, try restarting the laptop and immediately start tapping the f8 key until you see a screen with several boot options. This time select "boot in safe mode". The laptop screen will look different but will still allow you to run your laptop. Click on the "Start" button, then "Help and Support" and then "Undo changes to your system using system restore". Click on "Restore" and then select a date shown in BOLD when your laptop was running fine. Have the laptop restore to that date. After restarting, you should have full functionality. If this doesn't work, you may have a failing harddrive. Try reinstalling Windows. If it fails during loading, your harddrive is most like failing and should be replaced. If reloading solves the problem, you had corrupt software probably caused by a virus attack.
Sep 07, 2009 | Dell Inspiron 1525 Laptop
Hp pavilion dv9000 blue lights on won`t boot stuck just cli
Sounds like the harddrive went bad.
Some people call it the click of death.
Put the laptop to your ear near the harddrive and you will hear the clicking coming from there.
Good news is that it's easy enough to change the harddrive.
Bad news is you lose all your data to this point.
I hope this helps and i'm sorry that happend to you.
Dec 24, 2008 | Acer Aspire 5315 Notebook
Compaq Presario Notebook Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
