MP3 will not turn on
SanDisk 2GB, Black, serial # BEO804AOVK-2GB
30 second option did not work.
How do I remove the battery?
  • AGCOBB Jul 26, 2008
    I tried to take the cover off, but found no way to do it. No screws. No sliding compartment. My wife's MP3 resets often like that, but this one has no apparent access to the battery.
    What next?
    Genius:
  • 3,422 Answers
HI,
remove cover and reset by removing the battery.If you see screws behind then use a screw driver to take it out.
Posted on Jul 26, 2008
  • Priya darshan Jul 26, 2008
    I have just reviewed your model perfectly and found that there is no replaceable battery for your model.SanDisk 2GB.When the battery dies you have to buy a new MP# player. Most likely the
    battery will die before the hardware dies. This leaves you with a
    perfectly good MP3 player, but no battery to power it.
    If you need anymore help let me know.
Unit wont turn on??? was charging unit overnight,now wont turn on tried holding all buttons for 15,30 seconds
It sounds like it's time for a new battery. Here is your battery:
http://cgi.ebay.com/550mAh-Battery-SanDisk-Sansa-Fuze-2GB-4GB-8GB-/200582416758
If replacing the battery doesn't get this player up and running, you will need to contact Sandisk for repair or replacement of your player.
  • Website: http://www.sandisk.com/consumer-products/
  • Address: 601 McCarthy Boulevard, Milpitas, CA. 95035
  • Phone: 1-866-726-3475
  • Email: support@sandisk.com
Jul 04, 2011 | SanDisk Sansa Fuze MP3 Player
HI,
Try reseting it by holding the power button for 30 sec.
Let me know the result.
Jul 26, 2008 | SanDisk Audio Players & Recorders
Hi i have an sandisk sansa e260 4gb mp3/mp4 and when i turn it on all i get is the logo which is sandisk and if i put it on hold it and turn it on its say i locked it and the blue wheel is on and when i...
- Make sure the hold switch is set so the orange isn't showing.
if the hold switch is off
- Press and hold the power button for 30 seconds to force a hard reboot.
or
- Remove the 4 screws from the back, pull the battery, wait 30 seconds and then reinstall the battery.
Mar 22, 2011 | SanDisk Sansa e260 MP3 Player
My son can't get his sansa mp3 player to turn on.
Try this:
1.First, remove the battery. Then press and hold the "Menu" button for 30 seconds. This would cause the excess static electricity to be discharged from the player.
Insert a fresh battery and try to power it on. If it still doesn't power on, try the procedure again, but this time, press and hold the "Menu" button for 1 minute. Insert a fresh battery again and see if it would work.
2.
Plug your player in your computer and your Operating system should recognize it as a "Removable Disk" and it will have a drive letter. Right click on the M230 drive letter and select "Format". When the Format window appears, just make sure to set the File System type to "FAT" and make sure that the "Quick Format" option on the bottom section of the window remains un-checked. Click start to format the player. Follow the on-screen prompts.
3.
Use this link from the SanDisk website to download the Sansa Firmware updater:
http://kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
Mar 07, 2011 | SanDisk Sansa m230 MP3 Player
Sansa Fuze MP3 Player with 2GB* Hard Drive - Black: Light is on around the rim, but no display. I put...
Hold the the on/off button up for about 10-20 seconds and it should turn off. then you can just turn it on again. I fit doesn't work, then just wait for the battery to die and charge it back up.
May 06, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa wont turn on
I fixed mine! I removed the four screws on the back with an eyeglasses repair kit and then took out the battery and waited a few seconds then put it back in and now it turns on and i didnt lose any songs or anything!
Try this, I bet it might work. And the battery is the big white thing that looks like, well, a battery. its really obvious.
Thank you!
Dec 28, 2008 | SanDisk Sansa E280 MP3 Player
How to reset my mp3 player
Mine has froze a few times also, Remove the four screws on back cover and take out battery. wait just a little while and replace.... works for me ! Wish they would have put a reset button somewhere on player ( hummmm to easy..................
Nov 30, 2007 | SanDisk Sansa e260 MP3 Player
Sansa 2.0 mp3
Key lock means the HOLD switch is on.
Slide it the other way.
Best of Luck.
Nov 27, 2007 | SanDisk Sansa c150 MP3 Player
Sansa C240 freeze, wont turn on
Try a hard reset. Press and hold vol + and select for 20 seconds. If that doesnt work, you can try holding the power button for 30 seconds. Try to restart after either trial. If that doesnt work, you can call support and they can troubleshoot it for you. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Oct 09, 2007 | SanDisk Sansa c240 MP3 Player
Problem with my E250
perform this step, press and hold the menu button for at least 30-45 seconds then wait for aroun 10-15 seconds before turning on the player. If it did not work, remove the battery from the player and adjust its position/connectors to the player. If again it did not work try using a different battery for the player it maybe your battery died out.
Oct 07, 2007 | SanDisk Sansa e250 MP3 Player
81 people viewed this question
 Grubhead
Grubhead
