Question about SanDisk Sansa e250 MP3 Player
Communication problem My computer has trouble recognizing that the mp3 palyer is connected; the mp3 displays a "connected" message, then dispolays a "refresh database" and keeps cycling through these displays. the computer doesn't see the drive-- sometimes when I disconnect and reconnect it will temporarily see it and all is well, but usually loses it before i can add songs, etc. I'd greatly appreciate any advice!!
  • 1 more comment
  • Anonymous Jul 27, 2008
    my mp3 player has a similar prob. when i go to plug it in, it will not read the device... not only does it not read but it also does not charge
  • acanthus Jul 30, 2008
    I downloaded an audio book (.wma) file to my computer from my library. I had to download some new software to get it. I can't remember or access that site again. I think it was something like odm?
    After that the files downloaded to my computer with no problems and I can play them on the computer. I downloaded them to my Sandisk, but when I tried to play one on the device I saw a messge saying that I should sync my device to renew my subscription. I think that was it. I plugged it back into the USB port, but now my computer no longer recognizes the device. the device says it is connected, and even when I unplug it now it still thinks it is connected. I can't even turn it off. I can only see that one screen no matter what I do.
    I hope you can help me. Thanks,
    Cecelia Riehl
  • lostrealist Aug 06, 2008
    yea i got it to sync once or twice but after that it dont work. it has 2 bubbles {USB device not recognized} {found new device- usb device} the second one used to say {found new device - sansa e250} when i shoved the cord in hard enough, but it dont anymore.
I solved the problem myself, a couple weeks ago. I removed the battery and replaced it. That reset the device. Then I realized I needed to set it to the other USB mode--MTP, I think. Then I was able to listen to the book.
Posted on Aug 14, 2008
  • 8,596 Answers
OK, it's funny how all of you said you have the same problem, and yet you all have different problems.
sciguy - follow the instructions below on recovery methods
lost - you broke your usb port - try another
acanthus - i believe that player only recognizes Audible audiobooks
guest - see below
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
"Communication Not Available" message is displayed
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
New computer running windows 7, doesn't recognize mp3 player sansa clip when I plug it in. downloaded latest driver but wouldn't finish download because computer isn't seeing device.
Hi there,THe reason it isnt recognizing is becuase of your OS,windows 7 has porblems
recognizing devices such as your mp3 palyer...i reccomend redownloading the software driver and if all else fails return your mp3 palyer..
please rate me full... :)
Jan 22, 2011 | SanDisk Sansa Clip MP3 Player
My computer and itunes does not recognize my 8gb ipod touch. When i connect to my computer i get the following message.... USB Device not recognized
This problem is due to the drivers for the ipod being corrupted. Your best bet is to reinstall the drivers. The following URL is apples official trouble shooting for this issue.
http://support.apple.com/kb/ts1538
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 01, 2010 | Apple iPod MA446LL/A MP3 Player
My computer will not recognize my Sansa sandisk MP3 player. I tried to reset it, and when I get the "Please connect USB" message, it still won't recognize it.
Aug 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Mp3 not recognized by the computer
try re installing the cd program of ur mp3 or if you dont have any... try this. (for windows computer only)
1- plug your mp3 in the computer using your usb.
2- go to my computer.... in the left task pane. click view systems information.
3-the system properties dialogue box will appear.
4-click the hardware tab then click the device manager.
5-the device manager tab will appear.
6- click the portable devices then you will see the name of your device.
7-click the name of your device .
8- you will see in the general tab in the dialogue box that will appear 'device usage'
9- enable it.
thats all..
Jun 07, 2009 | SanDisk Sansa E280 MP3 Player
Rca Opal 4208 Blank screen
If stuck on initilizing then firmware went bad.
You need to go to RCA website download the latest firmware.
After you download the firmware.
plug in mp3 player to your usb device of pc.
After its plugged in install the firmware.
While its installing windows should find the palyer.
Leave it plugged in for about 1 hour to give the battery time to charge a little.
Jan 14, 2009 | RCA OPAL M4001 MP3 Player
Ilo mp3 player reads "*no files*"
my ilo mp3 palyers stores information which cannot be used because files are not present
Sep 14, 2008 | iLO (2 GB) MP3 Player
Phillips gogear 8 gb player
Well one thing for sure is that is your computer reading your media palyer, or do you even have it installed to your computer.
Jan 05, 2008 | Philips GOGEAR SA6045 MP3 Player
Always displays USB Connected
you need to reset your player turn it on and off hten plug it in the computer it will owork.
Jun 20, 2006 | iRiver iFP-795 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
