Computers & Internet Logo
Posted on Feb 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i upgrade my laptop in pentium 4? my laptop is only in pentium 3..
guru68
Level 2:
Sergeant:
  • Expert 347 Answers
  • Posted on Feb 21, 2011
guru68
Expert
Level 2:
Sergeant:
Answers
347
Questions
0
Helped
63277
Points
865
Sorry to say NO, pentium 3 and pentium 4 has different architecture and propably also the sockets not the same.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Need to replace the processor but dont know which one to get..
Intel Processor Pentium 4 672 3.80GHz 2MB Cache 800MHz FSB VT computer component
regrads
1helpful
2answers
I want to upgrade my inspiron 1100 processor
To be honest, the Inspiron 1100 is probably not worth the effort and cost to upgrade
The fast is proc is a 2.4 GHz Pentium 4 CPU, max ram 1GB of RAM,
You can find several dell portables below $500
http://www.dell.com/us/en/business/notebooks/vostronb/ct.aspx?refid=vostronb&s=bsd&cs=04
http://www.dell.com/us/en/home/laptops_great_deals/fs.aspx?refid=laptops_great_deals&s=dhs&cs=19
3helpful
2answers
Pentium 4 upgrade
The Compaq Presario SR2011WM supports following processors:
CPU/Processor
  • Socket: 775
  • Supports the following processors:
    • Pentium D 900 series Dual Core (Pressler, 65nm)
    • Pentium D 800 series Dual Core (Smithfield, 90nm)
    • Pentium 4 601 series (Cedar Mill, 65nm)
    • Pentium 4 600 series (Prescott, 90nm)
    • Pentium 4 500 and 501 series (Prescott, 90nm)
    • Celeron D series (Prescott, 90nm)
Hope it helped.
2answers
7helpful
2answers
I want to upgrade my hpdv1000 pentium M processor whats the maximum upgrade allowed for this? i have upgraded it to 2gb ram from 512mb and 250gb hd from 60gb and its doin fine.
You should be able to upgrade the CPU, since it seems that the DV1000's motherboard uses a socket CPU design. But, obviously, HP would rather have you choose the CPU that you want from the beginning and stick with it.
The first thing to do is to check HP website to see what other configurations were/are sold for your model. If they sell it with faster CPUs then you can upgrade to one of them...
PLEASE NOTE:
In order for a particular processor to be compatible with a particular laptop:
(1) the processor must be physically compatible with the laptop socket, in your case I thing you have a Soket 479 processor
(2) the laptop chipset must support the processor.
(3) the chipset front side bus speed must match the processor front side bus speed, in your case 400Mhz.
(4) the laptop BIOS must support the processor.
So I listed here processors with FSB at 400Mhz, I gues that DV1000 as a 855GM Motherboard that supports only 400Mhz with Socket 479
Pentium M
Banias
Pentium M 1.3 1300 1024 400
Pentium M 1.4 1400 1024 400
Pentium M 1.5 1500 1024 400
Pentium M 1.6 1600 1024 400
Pentium M 1.7 1700 1024 400
Dothan
Pentium M 710 1400 2048 400
Pentium M 715 1500 2048 400
Pentium M 725 1600 2048 400
Pentium M 735 1700 2048 400
Pentium M 745 1800 2048 400
Pentium M 755 2000 2048 400
Pentium M 765 2100 2048 400
Celeron M
Banias-512
Celeron M 310 1200 512 400
Celeron M 320 1300 512 400
Celeron M 330 1400 512 400
Celeron M 340 1500 512 400
Dothan-512
Celeron 205 1200 512 400
Dothan-1024
Celeron M 350 1300 1024 400
Celeron M 360 1400 1024 400
Celeron M 370 1500 1024 400
Celeron M 380 1600 1024 400
Celeron M 390 1700 1024 400
Best Regards
1helpful
UPGRADING FROM PENTIUM 3 PROCESSOR TO PENTIUM 4 PROCESSOR
To upgrade from a Pentium 3 to a Pentium 4 processor, you would have to replace the motherboard. The Pentium 4 processor has more pins on it than the Pentium 3 and would not sit in a Pentium 3 motherboard.
1helpful
2answers
Upgrading IBM ThinkPad T20 Intel Pentium III to Intel Pentium 4
Patrick, I'm glad to see your enthusiasm to explore and expand on your computer knowledge. Unfortunately I have to be the first to let you know that in this case your ideas on upgrading your systems by simply changing the processors just won't work.
First of all a Pentium 4 (or Centrino, which is the mobile version) literally will not fit into any of the systems you mention. All CPUs are made in specific form factors to fit into different sockets. Most Pentium 4 processors were made for Socket 478 or 478B sockets, which mean they have 478 pins on a chip roughly an inch and a quarter square. The high number of pins allow more signals and data to be passed simultaneously to the motherboard, one way the speed of the CPU operations were increased. Pentium III and older Celerons were mainly socket 370 chips on a chip almost an inch and three quarters square. The lesser number of pins were aligned in six concentric rows with a blank central square. Pentium II and even older Celerons used Socket 7 and any of a half dozen other schemes and were often put on daughtercards to make them somewhat interchangeable. It would be like trying to put a square peg in a round hole.
They also make other forms, like socket 775, 939, and the newest AM2, all of which are pin-incompatible. In certain situations there are adapters that will let you put a newer CPU into an older socket but the specific upgrades you mention have no equivalent.
There are other engineering factors to be considered as well. Not all CPUs run on the same voltage. Many desktop motherboards have been designed that are adjustable either by selecting the operating speed with jumpers (old style) or by electrically sensing the optimum speed of the CPU. Then there are the memory and bus speeds. The CPU has to be able to interact with the memory so they must share a signal speed. This is the Front Side Bus. Older Pentium 4 CPUs were designed to use PC-133 memory but more powerful CPUs. certainly any in the 2.0GHz and up range, are designed for Double Data Rate (DDR), which is PC-2100 up to PC-3200. The pin configuration of the memory is different also to reflect and optimize the faster design. Of course there is now a DDR2 design and most recently DDR3. Core-Duos and Quads use the DDR2 and DDR3 type memory.
Another factor is heat. Faster CPUs run hotter. the system must be designed to accomodate and release the greater amount of heat generated, thus there are larger heatsinks and fans and more vent holes. Otherwise the CPU would start acting erratically and eventually burn out.
Things would be slightly different if you were talking AMD chips, as the socket 472 was much more versitile and could handle a wider range of CPUs and speed, from Duron to Sempron to Athlon XP, all because of the way AMD designed their chips. Of course, they too had to upgrade to surpass physical limitations, leading to the socket 754 and other newer designs.
Desktop machines are much more flexible to upgrade because of the space available and the fact they are designed with expansion slots. If you need a higher video card to run games, or more com ports to run extra printers or whatever, you can generally place a card in a slot to add the functionality. If you reach the design limits of a motherboard you can usually swap it out. Not so with laptops.
Laptops in particular are hard to upgrade because everything is integrated into or designed to plug into the motherboard, which has to fit the case properly like a jigsaw puzzle. This is not to say it is impossible to upgrade somewhat, but usually for laptops it means putting a faster CPU of the same form. Here is an example that is specifically for the IBM T40 laptop:
http://bsnugroho.com/t40upgrade.aspx
No, if you want to upgrade to Pentium 4 or Core Duo or Core Quad speed and performance, you will have to go out and buy a laptop.
Please do not let this discourage your enthusiasm. You share the spirit of the old school to push the limits that has made all of these computer evolutions possible. Consider formal training to round out your knowledge and to expose you to more within the field.
1helpful
3answers
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
6helpful
Processor upgrade
Hi ryonsdad,
I checked out the Latitude D610 laptop, and you'll be glad to know that you have the following processor upgrade options:
1.) Pentium M 780 Processor - 2.26 GHz, 2MB, 780, Pentium-M Dothan, 533FSB (fastest upgrade)
2.) Pentium M 770 Processor - 2.13 GHz, 2MB, 770, Pentium-M Dothan, 533FSB
3.) Pentium M 760 Processor - 2.0 GHz, 2MB, 760, Pentium-M Dothan, 533FSB
4.) Pentium M 750 Processor - 1.86 GHz, 2MB, 750, Pentium-M Dothan, 533FSB
5.) Pentium M 740 Processor - 1.73 GHz, 2MB, 740, Pentium-M Dothan, 533FSB (slowest upgrade)
You can buy these processors from Dell Spareparts or otherwise from a 3rd party store.
Hope this helps!
Peace! :)
Acer laptop upgrade
Need more info about laptop model number.
Ram and hd should be easy enough to upgrade but cpu unlikely and graphics very unlikely as its usually onboard vga.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
