Question about Furuno GP31 GPS Receiver
How to connect furuno marine gps model-31 to a pc using serial port
  • fire1961 Aug 03, 2008
    What wires on the serial cable goes to the ones on the gp-31
    I needs that diagram please.
  • awilobempa Aug 07, 2008
    I bought a Furuno GP31, but I am unable to configure it with my PC, having Windows XP as operating sustem.
    There is no signal after connecting it to the system's com port.
  • 4 Answers
Connecting cable to PC - see
http://furuno.inforce.dk/graphics/14_Softwares/09_gps/FURUNO_GP-32_pc_connect.pdf
Posted on Aug 28, 2008
Antenna GPS Tram 1655 is compatible with GPS FURUNO?
If the Furuno unit you're referring to uses a GPS antenna with a coax (i.e. GP31/32) then the Tram antenna will work but the connector is wrong. The Tram antennas usually come with BNC connector and Furuno uses a TNC. Will need an adapter.
Oct 14, 2013 | Furuno GPA019S GPSDGPS HField Antenna...
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Connection to PC for Nav software
Assuming you have GPS input to your 1732 (i.e. GP310/320 sensor), you'll need a 7 pin NMEA data cable (000-154-028) wired to a D-sub 9 pin (serial) plug. The shield goes to pin 5, blue to #3, & white to #2. Jumper pins 7 & 8 together. The 7 pin cable goes to Data port 3 of the 1732.
Jul 12, 2010 | Furuno Navnet 1732 GPS Receiver
Need software to connect GP31 via serial to USB cable to W7 PC
Make sure you installed the driver for the serial to USB adaptor cable.
Jun 30, 2010 | Furuno GP31 GPS Receiver
I have bought a ICOM VHF m601 and I want to connect the furuno gps 31 to the VHF. Is this possible ?
Using the nmea output from your GP-31 to the nmea input on the VHF. Enable the GLL Sentence and make sure the port is set for nmea0183. Remember hooking nmea up it's positive to positive and neg to neg. Once that is done and you have a fix you should have lat and long on your vhf.
Mar 09, 2010 | Furuno GP31 GPS Receiver
How to interface a furuno 1833c navnet to a usb port and how to download waypoints to my pc.I have the older 9 pin pc cable and a usb adapter cable.Looking for usb drivers and software to make it work.
The display uses a serial interface, otherwise known as a comm port. You can get a USB to DB9 adaptor practically anywhere. Once you have a serial connection, you will need software such as MaxSea to send the waypoint with.
Jan 11, 2010 | Furuno 1833C/NT GPS Receiver
Can I use my furuno gps navigator to supply position data to my rdp-139 chartplotter and if so which wires need to be connected
Yes the output forom the Furuno GPS (like a GP31) will be yellow and green, hook these to theinput on the plotter blue (or black) and white. Use Data1 on potter as the input and select a nav source of "ALL" in setup menu.
Jun 05, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Gps
Hi fire1961,
Downloading data from my FURUNO GP-30 gave me no problems. But it took me long time to figure out why I coudn't upload waypoints and routes to the GP-30 via the serial port in my ThinkPad T30.
I tried nearly everything tested the cable, tested a lot of different software and even wrote a little c-program to communicate with the serial port. I also tried a serial-to-usb converter with no results. Then I stumbled over this RS232 Tutorial. According to this - serial ports are not just serial port but can be divided into three general categories:
The types of driver ICs used in serial ports can be divided into three general categories:
* Drivers which require plus (+) and minus (-) voltage power supplies such as the 1488 series of interface integrated circuits. (Most desktop and tower PCs use this type of driver.)
* Low power drivers which require one +5 volt power supply. This type of driver has an internal charge pump for voltage conversion. (Many industrial microprocessor controls use this type of driver.)
* Low voltage (3.3 v) and low power drivers which meet the EIA-562 Standard. (Used on notebooks and laptops.)
Then I installed the waypoint upload software to my ten years old Compaq Presario and suddenly I could upload routes and waypoints but only via the on board serial port. The serial-to-usb converter didn't still work.
So if people experience no result trying to upload data to these old GP-30's from their notebooks and laptops. Then I think it could be a matter of these Low voltage ports not are able to provide the FURUNO device with enough voltage. See the above RS232 Tutorial.
Best Regards
Lars Erting
Aug 03, 2008 | Furuno GP31 GPS Receiver
Software
Buy it from a Furuno dealer like me The product is MaxSea NavNet version John Barry 847-746-0100
Feb 07, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno GP31 GPS Receiver Logo
629 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
