Question about HP Photosmart C5180 All-In-One InkJet Printer
How can I print Black only?
Black cartridge is full. Color cartridges are empty.
Best buy epson printer, use this if you allow only one cartridge
Posted on May 27, 2010
    Guru:
  • 731 Answers
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Posted on Jul 28, 2008
    Habit-Forming:
    Scholar:
  • 38 Answers
Here is a solution to print the hp printer on black color. Follow the below steps:
    ·Select your HP printer from the list of available printers.
    ·And then select the Paper Type/Quality menu.
    ·Now click the triangle next to Color Options.
    ·From the Color menu, to select Black color.
    ·Select Black Print ink cartridge and then click Print to start the printer job.
    If you have any doubt or issues you can also contact our customer support to help you regarding your HP printer issue @ +1-800-836-3987 or visithp oj 6830 installation
Posted on Aug 02, 2017
My photosmart c4500 is my first and probably last HP printer... works better than the desktop I had from them....
Anyway when you have ink on both sides, if you have grayscale -high quality- selected it will always print full color and burn out your cartridge super fast.
If you select black only, then it will print grayscale.. and I'm talking grayscale--NOT black only.
Posted on Jun 07, 2013
  • 3 Answers
SOURCE: Why can't I just print in black if my other
Try opening advanced optios and select print in black and white only. Hope this helps
Posted on Aug 05, 2009
  • 125 Answers
SOURCE: ink cartridges
Go through your standard print procedure. File>print then look for the properties button which is usually on the top right of the window. Press Properties and look for either Printing in B/W or grey scale. That should prevent your color cartridges from printing. After you check that box, you should be able to print black only.
Posted on Aug 19, 2008
pagebor
  • 2785 Answers
SOURCE: Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Posted on Dec 17, 2008
  • 583 Answers
SOURCE: hp color laserjet 2600 n it will not let me print
hp 2600n printer has no overriding settings for bypassing empty color cartridges.if you try it by swapping chips like we do on other models the colour printing will permanantly disable and will never print colour even after you replace colour cartridges.thats the way hp has set up 2600 laserjet.dont even try any bypassing method or you will spoil whole printer.many people fail the printer by just trying to bypass it someway.
thanks.
Posted on Jul 08, 2009
cene765
  • 787 Answers
SOURCE: why can't I print black and white when color empty
Because the printer need all cartridges not empty to initialized and printing, scanning or copying.Just replace the empty ink.
Posted on Nov 06, 2009
I have a lexmark z2320 inkjet printer the colour cartridge is empty should it still print the black is full
I'm not a computer geek at all, but I find the color cartridges always run out first. Try to change your printer settings so it will only print in black and white and so uses the black cartridge and not the color one. If the the color cartridge is empty, the page will not print correctly. It may print some of the black color only.
Mar 26, 2011 | Lexmark Z2320 InkJet Printer
SCREEN READS "INSERT RIGHT CARTRIDGE" ONLY THE COLOR CARTRIDGE IS LOADED. CAN'T I STILL GET IT TO PRINT??????
No..! you need to install the black cartridge..!
The printer needs to be aligned with both the cartridges no matter if they are empty or full. So even if the black cartridge is empty and the color cartridge is full. The color will print and the black wouldn't.
But if you install only one cartridge it will not work as i said that the printer could not align to the cartridges unless both the cartridges are installed.
On some printers if you install the black one only it works. Without installing the color one. But on this printer It is mandatory to install both the cartridges together other wise it will give you error codes.
This model needs the cartridges to be aligned and then print and if you see inside the printer it has a carriage holder for two cartridges which moves back and forth to print.
So install the black cartridge and it will work perfect.
May 11, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Why do color cartridges have to be full to use the black only?
In order to prevent the "colour" cartridges from drying out,
the printer will often mix in a bit of "colour" when you ask to print with the "black" cartridge.
So, they are *NOT* "drying-up" -- they are being used.
Nov 06, 2009 | Office Equipment & Supplies
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
Black light & print cartridge light is blinking. I changed the black cartridge but did not change the color cartridge cause I never use color. Both are in the printer. Black Light is blinking and...
Unfortuantely , to solve the issue , sadly, yes you will have to replace the empty cartridge to continue to use the printer in a normal fashion. Its a sneaky and dirty trick many printer manufactuers do to make more money off of the customer through the purchase of printer ink.
Aug 25, 2008 | HP Computers & Internet
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Can't print when there's only black ink
Mostly it connot print w/out color ink if when printer message empty / sometimes the printer no message while ink was empty still black can print. it depends to the chip .
Jan 11, 2008 | Xerox DocuPrint M750 InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
3,988 people viewed this question
Seeker5211
Seeker5211
