Question about Car Audio & Video
Car amp blows 12 volt wire fuse
I have my grounds secure. My amp wired correctly, yet my my amp will blow the fuse that is in the 12 volt wire running from my battery to the amp. I wasted 20 fuses all of witch was 20-30 (size). The amp I have is 1600 watts, and recently I had a sony explode (250 Watt amp) hook up and it served no problem. Is there any certain procedures i need to take to avoid this? Should I just hook 12 gauge wire with no fuse directly to the amp?
The wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Posted on Nov 18, 2008
  • 631 Answers
A power wire with no fuse will set the car on fire if the wire shorts to ground or if the amplifier draws too much current through it.
A 12g wire is too small for a 1600 watt amplifier.
If the amplifier only blows the fuse after the remote voltage is applied (after the head unit is switched on - volume at minimum setting), the amplifier likely has shorted output transistors and will need to be repaired.
Posted on Jul 27, 2008
The cd player is not able to save eny thing like radio channals and every time when i start the car engin the cd make auto eject it mean that i have a problem with saving can u help me about this
you must have a digital volt meter and to find this out .
1. remove radio
2. take the volt meter and turn it onto dc voltage
3 take the black test lead and put it on ground for the radio it will be black find in harness on back of radio .
4 take the red test lead and find the yellow wire this is constant power must have 12 volt on wire doesnt matter if the car is running or off this wire is from battery it gives the radio power to save station presets and the clock and return the cd to were it left off from when radio turned off.
if no power at yellow wire go to fuse panel and use your digital voltmeter to check fuses for a blow fuse . take the meter turn it on meter to dc voltage and the take black test lead and find a good ground (clean piece of metal and then the red test lead start touching testing the fuses.
(turn your car ignition switch to run but dont start car) why some circuit in car only power up when you have car ignition on ....)
on the fuse there is the amp rating in the dead center on either side of the rating is the blads of the fuse expose to test the fuse touch the red test lead to the left and see if you get 12 volts. then test the right side of the fuse to see if you get 12 volts if not fuse is blown . do this to all the fuses untile you find a blow fuse you could just pull one fuse at a time untile you find blow fuse. if you do this make sure right amp fuse get back to the right spot in fuse pannel. if not you could have a fire maybe or melt something in car if a circuit fails and goes to blow fuse and fuse is too big and fuse doesnt blow ....
http://www.tintingbyfredjohnson.com
Dec 28, 2010 | LG LAC-M3600R CD Player
Keep blowing fuse for radio what is colr of constant wire
The constant 12 volt wire is yellow. The accessory ( switched 12 volt wire) is red. The blue (power antenna) and blue/white (remote amp turn on) are also switched 12 volt wires. Make sure that they are not being grounded.
Oct 10, 2010 | Kenwood Car Audio & Video
On my 1972 duster,when i blow the horn,the fuse blows and the tail lights go out also. the same fuse runs both.what could be the problem?
This sounds like the horn may have a short in it somewhere. Does the horn blow at all? Try this: Make sure you have a good fuse installed to this circuit again. Disconnect the horn and place a volt/ohm meter set to DC volts on the horn connections. If there is just 1 wire going to the horn, put that wire on the red wire of the meter. Put the black wire of the meter to a good ground, preferably the negative battery terminal. Now press the horn and see if there is a reading of around 12 Volts. If so, replace the horn. If not, and the fuse blows again, check the wiring for a fray/short to ground. When you're looking at the horn of course, make sure the positive lead isn't shorting to ground as well.
I hope this helps! Let me know if you need any more assistance! :)
-Jason
Feb 11, 2010 | 1983 Plymouth Gran Fury
Wires keep melting and shorting outand blower wont blow
Are you using the correct size fuse? Is the relay new and good? You can check them with an ohmmeter in the ohm setting to see if you get a good constant reading.
Are the ground wires securely and tightly grounded? Are there any bare wires touching? You can also directly connect blower to 12 volts to see if the motor is faulty causing a short and burnt wires.
Jan 23, 2010 | Jeep Wrangler Cars & Trucks
Kenwood KAC-729S keeps blowing fuses. Checked all cables, re-ran power, remote, and ground. All good, still blows them at power-up.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Sep 19, 2009 | Kenwood KAC-729S Car Audio Amplifier
Rf top ac on rv keeps blownig the 3 amp fuse
The 3 amp is 12 Volt protection for the control board. If that fuse is blowing instantly, then you have a short in the 12 Volt system somewhere. More than likely it is somewhere between the Thermostat and the control unit. Check to see if you have 12V at the thermostat. If so, then disconnect the red wire from the thermostat and the red wire at the control unit. At the control unit side, use an Ohmmeter to see if you have continuity with ground. If so, that wire is the culprit. If not, reconnect the red wire and continue to the next wire. Do this until you find the wire that is shorted to ground. Of course, the ground wire will not be checked.
Hope this helps,
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
1999 Hyundai elantra died while driving found ecu fuse blown replaced lasted half a mile and blew again
Check your o2 sensor harness. The harness if not properly secured will rub on the axle to a point where it rubs through the insulation of the wire & shorts on the axle causing the ECU fuse (20A) to blow. Repair the harness & replace the fuse & bada bing! You should be in business! Hope that works. IF NOT follow this K.I.S.S.
Keep It Super Simple! It never fails!
Jun 04, 2009 | Hyundai Motor 1999 Elantra
1984 ford ranger keeps blowing the running light fuses. when i let it sit at idle it won't blow the fuses but as soon as i start driving with in 5 mins or so it blows.... any ideas?
short in the wires will need a wiring diagram and ohm/volt meter to locate the problem, test lights work well to.
you will need replace the fuse with a light bulb so that the power will not go away. and you will have to search for power going straight to a ground source.
usually a raw wire from rubbing somewhere. can do a quick visual inspection first for the obvious, and then use the meter at certain points till you find a volt drop.
May 13, 2009 | 1984 Ford Ranger
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Keep Blowing Fuses
Sounds like the amp is shorting somehow. You are obviously shorting out somewhere between the battery and the amp. Are you sure you grounding location is a good one? is the fuse blowing only when you turn the stereo on? Something is not hooked up correctly.
If the fuse at the battery is blowing then it's a short.
If the fuse on the amp is blowing then its probably a bad amp.
Jun 12, 2008 | Kenwood KAC-728S Car Audio Amplifier
Car Audio & Video Logo
646 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
