Question about Mitsubishi WS-55809 55" Rear Projection Television
Error 22 My model is a WS55909, but I believe the electronics are basically the same. Self diagnostic says error 22: Short circuit protect. All the fuses appear to be fine. Another FixYa guru told me to check for a leaky capacitor C9A60 and I'm not sure if he meant a current leakdown test or to visually look for defects. It is not an electrolytic capacitor, so I don't think it would "leak" anyway. Here's the link to that discussion: http://www.fixya.com/support/t834506-mitsubishi_v_19_short_protect Service manual is vague on this, but I think the tvuPC monitors 24v supply on pin 46 and activates the short-protect if 24v isn't in range. Do you know if this is the only thing that causes this error? That would really help me out as this would narrow my troubleshooting down to the low voltage power supply. Thanks.
  • 4,234 Answers
The cap you referred to is a ceramic cap and is not likely to show any defects. These can short however and cause problems. If you can get one, just replace it. I agree with the initial post. The typical cause of the 24V line fuses to open is bad convergence ICs. Have you replaced them yet? I'd start there.
Dan
Posted on Jul 28, 2008
Error code 18 on Mitsubishi WS-55311
This is a V20 chassis, circa 2002
Available error codes for this unit are as follows:
12.....No error has occurred
21.....X-Ray protect circuit
22.....Short protect circuit
23.....Horizontal deflection failure
24.....Vertical deflection failure
Jan 07, 2015 | Mitsubishi Televison & Video
MITSUBISHI WT-A42 ERROR CODE 22 "SHORT PROTECT CIRCUIT"
error code 22 is a short protect circuit. this means the tv has found a problem in the tv and will not let it turn on till fixed. this could be several different circuits in the tv that is causing this. we need to test some parts to see what this is. the most common is a shorted convergence circuit. a repair on this would range around 400.00. You should check using a multimeter and also you should be good at soldering
PS:I strongly advice if you don't have experience in electronics then better leave this job to a tech
Feb 17, 2008 | Mitsubishi WT-42313 42" Rear Projection...
What does a blinking orange light on 65" Mitsubishi dlp rear projection TV mean?
Self Diagnostics
The V18 Chassis features Self Diagnostics to aid in troubleshooting problems that may cause the set to
automatically turn off or "shut down." The "Timer/Power ON LED" provides an indication of the sets operation,
and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
To activate the Error Code Mode, while the set is OFF, press the front panel "INPUT" and "MENU" buttons
at the same time and hold for 5 seconds. The LED will flash denoting a two digit Error Code.
Note: The Front Panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
Jul 24, 2014 | Mitsubishi WS-65809 65" Rear Projection...
TV will not turn on 2-1 and 2-2 error. ws65807
Mitsi has this information posted in regards to the 2 errors you have indicated. "2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies)" Also these 3 tech notes were found. "1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB.
2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB."
I hope this points you in the right direction.
Apr 19, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Mitsu wt42313 error 22 any ideas?
error 22 "short protect circuit"
Bad convergence IC, also replace 5A picofuse.
Dec 29, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi 50111
Run the diagnostics.
With the TV power cord plugged in, press the 'INPUT and 'MENU' buttons at the same time -- use the buttons on the front of the TV, NOT the buttons on the remote; a diagnostic Error Code Operational Check will begin, utilizing the 'POWER ON' LED (the green 'POWER ON' indicator light).
There will be a pattern of two sets of flashes, with a pause in bewteen flashes; this sequence of flashes will be repeated a total of five times.
The Error Code designations are listed below:
Error Code Description
12 No eror has occurred.
21 X-Ray Protect circuit.
22 Short Protect circuit.
23 Horizontal Deflection failure.
24 Vertical Deflection failure.
I hope this information helps.
Jun 17, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi v-19 short protect
My suggestion based on past repair''s of these kinds of problems is replace the TV with a new LCD and live happily ever after, don't waste your money, a year from now something else will fail, this is for sure.
May 23, 2009 | Televison & Video
I have a mitsubishi ws-55809 power comes on and then goes off
try to check it again as these are the only codes for your model.
3. Error Codes
“12” ... indicates no error has occurred.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
Mar 14, 2009 | Televison & Video
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
Jul 25, 2008 | Televison & Video
Mitsubishi ws48313 error code 22
that usually refers to either a diode or transistor in the xray protection circuit. There are only about 8 or 9 components that can cause that you will need the service manual to isolate which components make up that protection circuit. If you do have the service info and would like it I can post a link where you can get the mitsubishi service manual emailed to you cheaper than anywhere else on line.
Apr 02, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
