Question about Video Cameras
Sony Handycam DCR HC42 Video Capturing
How can I get my videos from the tape to my computer, which has Microsoft Vista- I am not very good at this and I keep hitting dead ends! I cannot download picture package which came with the camera to vista and when I try to get the computer to recognize my camera it seems to need the picture package to be there!
  • Amy1979 Jul 27, 2008
    Is that the same as an i.Link cable? I read about those, but it doesn't appear that my camera came with one- according to the book. If I go to Best Buy, can I get one there?
    Champion:
  • 203 Answers
You should be using a firewire cable to transfer video from cam to comp-cable comes 4 pin to 6 or 4 pin to 4 pin use 4 x4 for laptop and 4 x 6 for tower-make sure comp has port-not usb which is only for stills-once cam is connected or before open movie maker in vista and it should work or connect cam and computer should recognize it
Posted on Jul 27, 2008
  • Robert Vandenberg Jul 28, 2008
    i link is sonys name for 4 pin to 4 pin firewire cable-no camcorders include it-buy any 4 to 4 pin cable you can-sony more expensive and no better than best buy geek squad or dynbex brand-if computer has same size plug as cam it's 4x4-if larger on comp it's 4x6 pin
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-hc42 video camera problems
Buy a Sony-make head cleaning cassette and play it in the camera for 10 seconds. Do not play for more time, neither forward or reverse the cleaning cassette, otherwise you will damage the head of the camera. This cleaning cassette is to be thrown when it is fully played (and not rewound!).
Nov 30, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Where can get the sony handycam DCR-HC42 device drivers support Windows vista
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Aug 31, 2009 | Sony Handycam DCR-HC42E Mini DV Digital...
My lcd on my DCR-HC42 is not working totally but i can use the view finder in capturing photos and videos....whats wrong with the LCD?do i have to bring it to a repair center?
it is simble try to open ur camer and remove ur lcd there is a connector that connecting lcd and bord that called lcd fpc chaing that strip it will work
Jul 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony handycam dcr pc350 video capture problem with vista
As per Sony Support, DCR-PC350 is compatible on Vista, however there is an update of picture package available at Sony Support.
Download update and check the camera file transfer operation.
Jan 16, 2009 | Sony Handycam DCR-PC350 Mini DV Digital...
Import video from Sony handycam DCR-SR42 to computer
Does your camera having a docking station? If so, press the "burn to disc" button on the docking station, while the USB is connecting camera to computer.
Oct 27, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Video Cameras Logo
436 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
