Question about Bissell Vacuums
I can see the height adjuster under my Bissell pet hair eraser vacuum, but it doesn't adjust. The parts don't look like they're touching. It's been iffy since I took it out of the box. Now it doesn't adjust at all. Used only five times. Looks like I should be able to fix it myself. No local repair available. Could you help please?
  • Anonymous Mar 13, 2014
    Adjuster knob doesn't even touch roller plate on highest setting; doesn't appear worn.
  • 328 Answers
Http://uk.bissell.com/images/UserGuides/3920E_508.pdf
This is the pdf manual. If you look at page 12 you'll see that the bottom of the machine has been pictured. Between the middle wheels near the brush (where arrows 4 and 2 are) you'll find that the adjuster bar has a sprung mechanism. Now this is easy if you have time! If you take off the or just inspect the bar, check to see that nothing is clogged behind it. If it looks fine, check with your other hand by moving the rotary dial a couple of times and your other hand pressed down on the central bar between the wheels - if you can feel that the bar is moving whilst you turn the rotary dial then it should be working. Sometimes the spring that connects the dial to the bar can loosen and this may well have been the case. If you can unscrew the assembly do it gently as it will pop up to see if the spring has been put in place and then carefully put everything back together.
Some uprights don't allow the height adjuster to adjust whilst in the upright position though but if it doesn't adjust at all then the spring has definately moved.
Posted on Jul 26, 2008
Bissell pet hair bagless instruction manual
Do you mean the Bissell Pet Hair Eraser bagless vacuum cleaner? The user manual for this vacuum is available from the product page: http://www.bissell.com/pet-hair-eraser-vacuum/ . Look on the right hand side of the page. The direct link to the English version of the manual is: http://www.bissell.com/assets/0/132/134/228/e5babada-7240-40ea-93c0-90427ed32741.pdf . Note: you will need Adobe Reader or a similar product to access (read/print) the manual.
Bissell has a number of vacuums for cleaning up after pets. Look for your vacuum here: http://www.bissell.com/pet-vacuum/ . The manuals for most are on the product page. For example, there is also the Bissel Pet Hair Eraser OptiClean Cyclonic vacuum. The manual is here: http://www.bissell.com/assets/0/132/134/228/dd4a7280-504f-4483-84a1-bfcc3a239f45.pdf . Older product manuals may be available here: http://www.bissell.com/customer-support/ . Scroll down to the Users Guide search box.
I hope this helps.
Feb 07, 2013 | Bissell Vacuums
Bissell pet hair eraser-the brush is not rotating but the suction is working on the removable parts
That means that you need to replace the belt. Here is the belt you need and a manual you can view which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Jan 01, 2010 | Vacuums
Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Dec 30, 2009 | Bissell Upright Vacuum - The Pet Hair...
Last time I used my Bissell Pet Hair Remover vacuum it smelled like something was burning and it left a black mark on the carpet. What should I do?
When you smell burning like that it usually indicates that the belt is worn and slipping on the motor shaft. You probably need to change the belt. You can get the belts for your model here:
Nov 11, 2009 | Bissell Upright Vacuum - The Pet Hair...
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
Vacuums Logo
299 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
