Question about Canon CanoScan 3000F Flatbed Scanner
Scanner Setting up scanner. What do I need besides the power adapter?
Need driver software
Posted on Oct 01, 2008
  • 1,601 Answers
Just a USB cable and the software...
Posted on Aug 01, 2008
Realistic pro-36 scanner mod. no. 20-137. what adapter would i need to operate it without batteries??
That will be a 9v, 150ma power cord that has a 5.5mm plug. I apologize, but I don't know where to get one off hand besides maybe Amazon.
Here is a site that will have a manual, that has the original part number listed:
RadioPics Database Schematics Manuals Etc
Jan 18, 2017 | Radio Communications
What power supply is needed for benq 4300 scanner
you need (15 volt 1.25 amp) power adapter for
benq 4300 scanner
Aug 02, 2014 | BenQ 6678-9VA 52W 4300U Flatbed Scanner...
Can a 12V 6A power adapter replace a 12V 1.5A power adapter?
I'm not an electrician, but I do know that as long as the voltage matches EXACTLY (don't take the chance, most devices don't have a good resistor, or don't have one at all!), the current doesn't matter. I'll explain myself:
A consumer device (your scanner in this case) uses all the current it needed, and it practically doesn't need more! It take just what's necessary!
Connecting adapter which provide LESS is not enough, but more - isn't harmful!
Hope I helped,
Mar 14, 2010 | Canon CanoScan 4400F Flatbed Scanner
What power supply is needed for hp scanjet 2400
It is depends on your scanner power adapter and where u purchase the scanner from. Here if your scanner is from US then the adapter power input should be 100-120V 60Hz AC, if your scanner is from Euro, UK or Australia, the it should be 200-240V 50Hz AC, while if your scanner is from others place that not listed above then it should be 100-240V 50-60Hz AC.
But the best way is look at your adapter itself, u'll notice the power input and output from the adapter sticker.
If you lost your adapter then be sure to purchase 1 that can output a 12 VDC, 340mA, 4.22W adapter to the scanner.
YBC (/\)
Oct 20, 2009 | HP ScanJet 2400 Flatbed Scanner
Setting up Scanner
Mainly you need to run the software setup, plug it in to the power adapter and to the computer, then turn it on when the software says to. If you don't have the software, it can be downloaded from the HP website:
Setup Guide:
Mar 12, 2009 | Office Equipment & Supplies
Power won't turn on at all.
would suggest to start testing at the power adapter if the power adapter is not working properly you will need to replace it with a matching power output adapter or exact same model if you can find.
if the power adapter is not the problem, its probably not worth the repair, up to you, I haven't looked into your scanner to see if its valuable or not.
Well a new scanner / all in one printer with a scanner goes around 50usd.
Jan 05, 2009 | Visioneer OneTouch 8650 Flatbed Scanner
Power supply
The Umax 3400 scanner uses an adapter with 12 volt 750mA output.
You can see it / buy it ( $11.95) on the UMAX website.
Just Google: umax scanner power adapter
Aug 24, 2008 | Umax Astra 3400 Flatbed Scanner
Scanner has no power
This issue could be due to two reasons 1). The power adapter of the scanner could go bad and needs to be changed, and the other the Scanner it self is gone bad, however you can try few steps given below.
1. Remove the scanner power adapter and clean the metal contacts on both the ends also clean the metal contacts on the scanner as well if possible.
2. Reseat the power adapter on both the ends.
3. Plug the scanner to a different or known good power source
4. Disconnect and bypass the power extensions if used and connect the scanner directly to the wall jack.
5. Try a similar know good power adapter.
Malik Khan
Jan 31, 2008 | Epson Stylus Color 750 + Perfection 1200...
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Canon CanoScan 3000F Flatbed Scanner Logo
62 people viewed this question
old marine
old marine
