Question about Epson Stylus Photo R260 InkJet Printer
Epson R280 I got this printer so I could print on DVDs. The problem is that I have to set the input tray to the upper position to print on a disc, and it is almost impossible to get the tray positioned correctly. The two red lights blink when the printer does not like the tray position. I have printed a couple of dozen discs, so I know it is possible. Is there a trick to getting the printer to recognize the tray. Inserting it is a no-brainer. It just slides into the openings on each side, but the lights blink, and I cannot print. Any help will be greatly appreciated
You must power on the printer with the catch tray in the lower position. Let it complete its cycle. When it has completed the cycle move the tray to the DVD position, insert the DVD carrier with
your blank to be printed, aligh the arrows and presto there should be no problems. You Must Initiate the printer in the lower position or it will fail every time.
Gerald
Posted on Dec 29, 2008
What is wrong with my Epson R280 printer when the ink appears smeared down columns of a spreadheet
Probably dirty heads on the nozzle. In most inkjets there is a maintenance option to clean the heads. I would first clean the heads, and then make sure that the print heads were aligned. If that is all squared away then check for any driver or firmware updates. Finally get some rubbing alcohol and gently clean the print head. Sometimes if the printer is not used that often the ink will congeal and smear.
Oct 19, 2014 | Epson Stylus Photo R280 Series
My Epson stylus Photo R280 prints like its printing double and is very unclear..how do I correct this problem
You need to align/clean your ink cartridge. Look under the Printers, select your printer and go to Properties. There should be a tab for maintenance.
Feb 16, 2013 | Epson Stylus Photo R280 Series
How to clean printer heads on an epsen printer
take out cartridge and re position turn on and printer will self align . if no instructions available take out cartridge and wipe with cotton , return and self align ,
Mar 20, 2012 | Epson Stylus Photo R280 Series
Epson Stylus Photo R280 general error The printer has worked fine for years. All of a sudden 'general error' starts coming up. I understand this to be something is jammed in it. When I turn it on...
For Epson Stylus Photo R280 general error You may contact Epson Customer Service for any kind of help you require. You can also call on Epson printer support phone number at +1-800-204-4427 and for UK customers the Toll free Number +44-800-046-5291 we are also provide technical support in AUS Toll free number is +61-1800-954-262.
May 18, 2017 | Epson Stylus Photo R280 Series
I keep getting the message"the
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Mar 11, 2011 | Epson RX595 Photo All-In-One Printer
Epson stylus photo R280 won't print due to false low on ink
Try using a soft cloth saturated with rubbing alcohol over the metal contacts. Make certain all residue to include spent ink or oil from your fingers have been removed. Let air dry. If your printers Print Head can be removed separately, that is the way to go when cleaning components. It has been known that Print Heads fail also and need replacement.
Feb 07, 2018 | Epson Stylus Photo R220 InkJet Printer
Dvd/cd tray same problem as others posted here
My experience (with the R280) MAY have some relevance.It turns out that, should you turn the printer power on WHILE the output tray is in the upper (DVD/CD) position, you get an undocumented pattern of error lights, error message, and no ability to print. The cure (for the R280) is: just move the tray to the lower position and leave it there long enough for the printer to complete its power-up cycle and initialization, after which the green POWER light will be solidly on. Then you can shift the tray to the upper position for DVDs, or go ahead and print on paper where it is. Epson "technical" "support" people all deny that this is the way it works, and they want me to return the printer for replacement. I have confirmed the behavior on TWO different R280s. They also deny that their CD-Label software scatters "CDLabel.alb" files whenever you load a photograph as background, but that's another issue, and fortunately non-fatal.
Jun 20, 2009 | Epson Stylus Photo R340 InkJet Printer
Mac OS 10.5 Leopard
As per someone elses post here:
* Source: Manual
* Size: A4
# Click Properties.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R260 InkJet Printer Logo
390 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
