SOURCE: Garmin Nuvi 750 GPS
Have you tried this?
You can try this step that I found. If you tried loading other mapas try this.
You will need to erase a file from the units memory. Connect your GPS system to your computer; go to start then ‘My Computer’, and double click on your device file (mass storage system), there you will see a folder named ‘Garmin’.
In this folder are several different files, look for file named gmapsupp.img. Right hand click on this file and delete as this file is causing the maps to lock.
SOURCE: "No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
SOURCE: Garmin Nuvi 205 keeps saying no maps available ???
First you will want to empty your recycling bin & clear your
temporary internet files before re-downloading the Garmin_RMU_2010B.exe
file.
Below is the remainder of the fix I received from Garmin support
and it worked for my unit. Hope this helps.
1. Extract the downloaded file Garmin_RMU_2010B.exe using 7zip(7zip.org) or WINRAR.
http://downloads.sourceforge.net/sevenzip/7z465.exe 32 bit
or
http://downloads.sourceforge.net/sevenzip/7z465-x64.msi 64 bit
2. After extracting, the files should be available at the location where you extracted the files.
3. Go to the extracted file location. Click on the Windows folder.
4. Right click on the Setup.exe file and Click Create Shortcut
5. Right click on the Shortcut to Setup.exe file and Click Properties
6. In the target line add " -build_map_image 006-D0783-04 " at the
end of setup.exe". For example the end would look like xxx\Setup.exe"
7. Click Apply and OK.
8. Double click on the Shortcut to Setup.exe the map file will be
built. Leave the Window open till completion of all steps. 9a. Windows
XP: Click on Start>Run, then type in %Temp%. Another window will
open.
9b. Windows Vista: Click on the Start Button, in the Start Search, type %temp%. Another window will open.
10. The file is placed in subfolder named 006-D0783-04.
11. Copy the gmapprom.img file from the folder to the Garmin folder
on the Nuvi. (Double click on MyComputer>Nuvi drive>Garmin
folder) Overwrite the existing file.
12. The Nuvi should now have the lower 49 installed. If you have
any trouble with this fix, or are not comfortable trying it please call
our Software Support Department at 1-800-800-1020. Please be at a
computer that has high speed internet access as we may need to log on
to your computer to resolve the issue. Make sure you have the program
extracted using the 7 zip program provided above. Hours of Operation
Monday – Friday: 8 am – 7 pm Central time (closed holidays)
With Best Regards,
Joyce K
Software Support Specialist
Software Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Joyce K
www.garmin.com
SOURCE: Well my Garmin nuvi 1300 was working fine
it sound like someone has "unticked" maps go to settings then maps and map info and look for the screen that says city navigator, and tick box that should work unless someone has attached to pc and wiped maps
