I have to storkcraft monterey stages crib. I would like to convert it to a toddler bed. I cannot find instructions. Please help my daughter is climbing out and I don't want her to get hurt!!
As lots of cribs-stage from Storkcraft, your bed instructions are permanently attached on the board, below the mattress. And for the almost beds, the mattress frame has to be purchased separately, to convert it to a full size bed.
Per the companies website (storkcraft.com) it doesn't look like the Ariel is a 3 in 1 but a 2 in 1. The manual is here http://www.storkcraft.com/docs/all/04588-43.pdf and it mentions converting to a twin bed, but not to a toddler bed.
Possibly put the mattress all the way down and remove the smaller side rail for a 3 sided toddler bed. Make sure the frame is sturdy enough without the 4th side.
have a crib passed down third baby now in use but one of the stabilzers bars has broke from taking down moving and setting back up.. Please Help model no#231 made 2005 cheery wood and name of brand Bambino Reale
I also have this crib. The instructions are on the mattress base. (the wood that holds up the mattress) . If yours is not there, here's a link to an image of it..
The directions are on the platform that supports the matttress I believe it's number 7 on how to convert to a full size. You have to buy a frame for a full size bed and of course the mattress and box spring. I hope this helps
I just went on to the Storkcraft website for Canada and found some installation instructions. There are instructions for the initial set up, for converting to a toddler bed, and converting to a daybed. Here's the link . On the right side there are 3 links for Assembly instructions. The first is the initial assembly, the second shows the toddler bed and daybed assembly, and the third is a complete installation manual. Hope that helps!
I too, need to convert my crib to the toddler daybed. My daughter climbed out last night! Anyway, I was searching for my instructions and then remembered the instructions are attached to the bottom of the mattress board......hope this helps.
there should be a sticker somewhere on the furniture that tells you exactly which set you have. from there you can either email them or call and they will send or fax the instructions. hope that helps.
