Question about Frigidaire ATF6000ES Front Load Washer
Can you use Oxyclean along with detergent in front loaders?
Saw an advertisement for Oxyclean's use in front loading washing machines.
Mix powder and liquid detergent? Put it in the dispenser drawer or right in the tub? Has anyone else seen this ad or tried it? I have to wash VERY dirty and oily clothes.
Thanks
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Posted on Oct 07, 2008
    Novelist:
  • 116 Answers
I have not seen the ads but my wife uses Oxyclean in both of our front load machines with no issues. It seems to work great.
Posted on Jul 28, 2008
Use Top Loader or Front Loader detergents Do you need to dissolve all powders or liquids before washing Can you alter spin time or speed
the use of liquid detergents is recommended over powders in washing machines as they do leave a mud build up over time in the bottom of the wash bowl
no they do have to be dissolved before use
spin speeds are set in the machine program and cannot be altered
spin time is set in the machine program and cannot be altered
use the recommended detergents for the machine because if you use top loader detergent in a front loader it will froth up excessively and cause problems for a front loader machine
the suitability of use for the detergent ( powder or liquid) is clearly marked on the labelling on the bottle or packet
Feb 24, 2015 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
What is the recommended washing powder
any brand that states specifically for front loader machines. From experience I would prefer to use liquid detergents specific for front loaders as there are less harmful products that rot and corrode parts in the machine.
Aug 17, 2013 | Bosch Classixx WFL 2066 Front Load Washer
I have a Samsung Silver Care front loader washing machine. When I turn it on water comes out the detergent dispenser drawer and a little oozes out of the main front door. Any ideas? Thanks, Kelly
Remove the dispensing tray (look for an under side spring clip or release) and check the fluid exit point--the machine washes the detergent into the drum along with other washing compounds. You may be better off using a liquid detergent rather than a powder. This may also fix the main door leakage too. Hope this helps!
Aug 15, 2010 | Samsung WF328AA Front Load Washer
When in wash it dosent remove all soap powder from clothes
I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
May 15, 2010 | Zanussi ZJ1217 Front Load Washer
Oxiclean
Mix one ounce OxiClean powder with your powdered detergent in the detergent dispenser of your front loading washing machine.
OR
Dump one ounce OxiClean powder into the washing machine before you add clothes.
May 15, 2010 | Kenmore Front Load Washer
Have a lg tromm front loader and am wondering if it is ok to run regular detergent instead of the hd stuff. C.
Not recommended. When buying the correct product you should also find the front loader much more economical on washing powder than a top loader.
Mar 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine doesn't comsume the washing powder.
use liquid detergent, less clothes, larger load size, or put the powder in first and let water fill up. u may want to mix up with your hand or like i do give a twist to the washing device to mix up better. but i did find this the problem when i used generic detergent for they go a little cheaper on the ingrediants try brand name like tide, or gain. cheaper not always better but i find these two work well for me and have a lasting scent.
Mar 29, 2009 | Whirlpool AWM8123 Front Load Washer
Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Feb 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
1,788 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
