The solution is to remove the grommet on the valve cover (for the small line) and replace it with a grommet for a 1985 CJ7 along with the PCV valve for the CJ7. Prior to replacing the grommet, you must bend a metal tang inside the valve cover using a screwdriver. This tang is what forms the "spring" in the built in CCV valve. Bending it up, opens the valve all the way permanently.
Next, take a 3/8 inch quick connect air chuck (the kind you screw into a blow-gun or tire chuck for use on an air compressor equipped with quick connect fittings) and replace the screw in nipple on the manifold (where the original tube attaches) with the air chuck. The chuck is an exact fit (threading and length)but has a much larger internal diameter for the crankcase gases to flow. Finally run a section of 3/8 inch fuel line from the newly installed PCV valve to the new air chuck nipple you screwed into the intake manifold. Attach a hose clap at each end of the fuel line and you're done.
you only have to bend it till it stays open by its self.i my self used a pair of long thin needle nose pliers,then put the grommet in.and i believe you are correct about the location of the tang,should be near the side.
