Question about Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range
Dacor ERD36 F1 blinking +
Im having trouble with my dacor ERD36 range with a F1 flashing in the control panel. Also the  baking button and the time button dont work, baking in the convection mode is an adventure in itself , you "never know what youre gonna get" So is there a simple solution to this? do i replace the ECU or Membrane or both? Can someone recomend, where i can buy dacor parts  for the lowest price
 I appreciate any assistance
mondo-
  • rwillis May 03, 2009
    The F! code appears when you press the contol buttons for 30 seconds plus the door is locked and will not open.
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Beeping with F1 on display
See if F1 stops momentarily after pushing cancel. If F1 returns you have a failed control (electronic clock). The board can be repaired at our shop, www.fixyourboard.com or you can purchase a new one.
Best Regards,
Bruce
Jun 22, 2010 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor Model# ERD36, Oven Element no heat & no error code flashes.
look for a hi limit thermo in burner box or on back of oven . if it has over heated this would cause this . dacor has a resetable one . it may be located on left side panel will have to be removed . ck elect sch tof location .. mm
Dec 04, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Clock is stuck in military time & I can not get it to go back
The newer Dacor ER36D can by switched from standard 12 hour to 24 hour military time mode and back by holding the CLOCK SET button for 6 seconds. That may work on older models as well.
Feb 28, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor rsd305
yes, you need to open the panel (in the center of the front of the oven when you open the door on the top) and press the reset button, there is a site that gives step by step instructions, but i can no longer find it
Jul 22, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
F6 Error
ok.. don't you any schematic manual in there...?
Jul 09, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Touch pad
Update - Turned the Circuit Breaker off to stove and turned back on. The second time I did this, it "fixed" the touchpad. Clock resumed flashing the time and all buttons work. Thank goodness no service call this time!
Feb 10, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor range natural gas to LP
I have the ERD36 and it runs on LP. Is this purchase a used oven? If not, I would tell the dealer to order it for LP.
Jan 16, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Oven door won't open
Hi... Having problems with my Dacor ERD36 as well, I came across this posting that might help with your particular situation of not being able to open the oven door.
Here is the link to the forum:
http://www.applianceguru.com/forum1/2189.html
In case you can't get to the forum link, here is the response:
Have a 2nd person at the circuit breaker turn off power. You press and hold the cooktime keypad. The other person turns the breaker back on. The display will show the 4-character ID code of the ERC (e.g., 1180). You have 30 seconds between each test.
Press and hold these keys on sequence:
convection bake
standard bake
pure convection
broil
timer 2 (momentary push only)
stop time
clock
Finally, we arrive at the test we want:
Open the door, push and hold cook time for 10 seconds. Self clean latch motor will activate. Door latch will complete a cycle. The test will end the ERC will display the time of day.
Complete this test within 30 seconds or you'll get an F0 code (stuck keypad).
I hope this helps.
patti
Dec 06, 2006 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range Logo
447 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
