Question about HP Compaq EVO Intel Celeron 1.7GHz / 256MB / 20GB HDD / CD-ROM / AGP Video Card / 10/100Mbps LAN / Wind PC Desktop
Network card driver need
I have not network card driver
  • Tim Babcock
    Tim Babcock May 11, 2010
    Whats the model number of your EVO?
  • 928 Answers
Click on the link below then click on your exact model number which you can find on the HP sticker then select download drivers.
http://h10025.www1.hp.com/ewfrf/wc/pfinder?query=EVO&dest_page=product&lc=en&cc=us&dlc=en
Posted on Nov 26, 2008
Windows doesn't detect a properly installed network driver
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver if you see a yellow ? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
the driver could be on the motherboard disk or the one supplied by your ISP internet service supplier or you might need to download it
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109025.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-pro-100-m/3000-2112_4-109029.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109002.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109004.html
hope one of these will help
Jun 10, 2012 | Dell Ethernet Card Network Adapter
I JUST INSTALLED A NEW XP PROFEESION and my LAN is showing connected but is not TRANSFERRING NOR RECIEVING data . it is at ZERO , ZERO point
u need to install the network card driver...of your motherboard CD
go to My Computer/ Right click/proeprties/Hardware Tab/Device Manager/Network Adaptor....look for any YELLOW ? or !...if so then neeedto install the driver...get that from the motherboard CD or the Cd that came with the PC...else search in google for the driver giving the network card model(network card model can be located on the properties tab as detailed above) refer image below....
you also may have to configure the network IP address....for that you will need to contact your internet service provider....
Nov 01, 2010 | 2wire 1000-200004-000 Network Adapter
My laptop network card dissapeared, i have no network hardware. How do I fix this problem
go to device manager and find the network card check whether the driver is installed or not, if the driver is installed properly then use genius driver professional or cobra driver pack to get the updated drivers
Apr 07, 2010 | Dell Ethernet Card Network Adapter
Ethernet light at the back of the computer does not light up, also does not recognise cable.
Check the dell website for support and drivers for your computer. go to www.dell.com and put your service tag into the proper section.
You either have the wrong driver for your network card or the network card is not functioning. You need to be sure the card is seated properly in the card slot first.
Chedk the device manager to see if the network card is recongnized. Go to your My Computer icon, right click and go to properties and then the hardware tab.
Look under network cards and see if you card is visible and if the driver is loaded for this card. If the card is there, try to download an updated driver for your network card.
I hope that you find this information helpful, if so, please leave feedback for me.
Thank You,
Brian .
Jan 25, 2010 | Dell Ethernet Card Network Adapter
I NEED LAN CARD DRIVER FOR D600 LAPTOP
If you want the driver for your Dell laptop, the best place to get it is at support.dell.com.You need to input the model you have, ( which I believe to be a Latitude D600), and choose drivers.
On the driver page, choose your computer's language, network for category and all for importance.
This brings up about 20+ possible downloads.
You then need to find the ones that apply to the network card in your computer that are labeled as drivers.
Anything labeled as firmware is optional and will upgrade the operation of your card if applied. Utilities are also optional and are usually used to change operational settings of the card.
There will be only one driver for your card that you have to download, everything else is optional.
Once you have the driver, look at the device manager in WinXP.
If the network card [ethernet adapter] is not showing there, then there should be an unknown device.
Right click on the unknown device and choose update drivers and point the update wizard to the driver you downloaded.
That should solve the problem.
Feb 18, 2009 | Dell Ethernet Card Network Adapter
Can i use a usb adaptor on the c700
Your laptop should have a built in network card and 10baseT network port, if your laptop does not have a built in network card you can use either a PCMCIA network card or a USB network adapter. Your desktop computer may not have a network card, you will need to purchase a network card and install the drivers.
To connect the two computers together you only need a cross over cable. If you use a hub you can connect two or more computers together using standard 10baseT network cables.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Help me
You need to download and install the drivers for the computer. You can download the drivers for each piece of hardware from dell's website:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_CEL_3000&os=WW1&osl=en&catid=&impid
Jan 25, 2008 | Computers & Internet
HP Compaq EVO Intel Celeron 1.7GHz / 256MB / 20GB HDD / CD-ROM / AGP Video Card / 10/100Mbps LAN / Wind PC Desktop Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
