Question about Sony Ericsson K610i Cellular Phone
I tried dear assistant, thank you for your troubleshooting. I did as you advised to reset setting, but the problem remains. The camera frame stays black, all the icons are there, but all the phone seems blocked. Just a moment ago I remarked, that it returns after a long while (2 minutes) to main page. I took this as a good sign. Before that, I always put the battery out.  Have you any other idea what I could do? Thank you so much for you immediate response so far. Sincerily (the phone could be also a k700i, written inside phone, the box I got the phone in, says k610i....)
  • webolom Jul 27, 2008
    dear robinson,
    thank you so much considering my problems. As far as I can see, it's definetely a k700i, which doesn't contain a memory card at all. I'm sorry for my uncopmetence, but the box I got the telephone in is the k610i-one. So I have to bother you again with these troubles.
    Sincerily
    Problem Solver:
  • 18 Answers
Check for the memorycard size is it the same that came with the handset try using the phone without the memory card for 24-48 hrs if the phone works fine without the memory card then the memory card is faulty if the phone still does not work properly then it should be repaired.If the phone is under warranty then give it to the manufacturer for repairs
Posted on Jul 27, 2008
Picture count stays on 9999
reset to factory setting, after do this set numbering to "by month"
hope this will solve your problem
Jun 29, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
The child lock engaged when a circuit breaker triped. I tried pushing the Rinse Only pad as per the manual. But, the dishwasher remains locked (light on) and won't run.
Hi Gayle, thank you for allowing me to assist you!
When the Child Lock light is on, the control is locked and no cycles can be selected or started. To de-select the Control Lock, press and hold the heat dry key or press down on the lock icon for approximately twenty seconds. If issue persists, try resetting the dishwasher by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit on. Select a cycle and your dishwasher should resume normal operations. I ask that you please follow up with a comment on the post, at your convenience to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Sep 27, 2013 | Frigidaire 24 in. PLD2850 Built-in...
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
MY Sony cyber shot DSC W35 camera's shutter is open and close repeatedly and asks for power off and restart but nothing is happening. PL advise
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera, press the RESET button located inside the Jack cover of the Camera using a sharp pointed object like ball pen or paper clip. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Jul 17, 2011 | Sony Cyber-Shot DSC-P52 Digital Camera
My DSC-T10 Sony Digital Camera fell down and now the new pictures taken are coming Blurry (hazy). My old pictures in the memory stick shows perfect. Please advise what could have happened.
Based on the information you've provided, it seems that the Lens Mechanism of the Camera is damaged when it fell down. The Lens of the Camera is not focusing properly while capturing the images. As the issue is with the lens mechanism, the previously captured images are displaying normally. I suggest that you try resetting the Camera and check if the issue can be resolved.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
Apr 01, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
How to disable the vibrate function in my sony cyber shot DSC-T70 and where i can find it
There is no option in the DSC-T70 Camera to enable or disable the vibrate option. The vibration in the Camera is a malfunction. The Camera may experience an issue where an abnormal internal vibration and an inability to properly focus and take pictures. Try the following troubleshooting steps and check if the issue can be resolved.
Follow the steps below to perform a manual power reset.
Turn off the Camera.
Allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack.
Turn on the Camera.
If the issue persists after the power reset, then reset the Camera back to factory default.
To reset the Camera back to factory default, select the INITIALIZE option under Main Settings 1 Menu of the Camera to OK. (HOME-->SETTINGS-->MAIN SETTINGS-->MAIN SETTINGS 1-->INITIALIZE-->OK).
If the issue occurs again, then service may be required.
We wish you a Happy Holiday Season.
Dec 18, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
When I turn my camera on, the screen remains black and says turn power off and on. Upon doing so, when i turn it on again, it begins beeping and says turn power off and on. But if I go to the view pictures...
Turn on the camera.
To reset the Camera back to factory default, press the RESET button located above the PHOTO button which will change all settings back to factory default. The images and videos will not get deleted.
Jan 30, 2010 | Sony Cyber-shot DSC-M2 Digital Camera
Itsays turn power off and on again and shutter comes out and back in about 3 or 4 times then stays shut
Turn on the camera.
Thanks,
KenSolutions
FixYa
Aug 01, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Powershot SD870 IS digital elf will not focus
If you've done all those steps, I would look at the physical attributes of the camera. Does the screen have gunk on it? How about the lens itself? You might also check to make sure the camera isn't set to video mode. In low light, that could make the view screen look a bit blurry.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 17, 2008 | Canon PowerShot A75 Digital Camera
Problem with menu system maintaining display
I would highly suggest upgrading the firmware. Best thing to do first when having odd glitches like that.
Nov 27, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Sony Ericsson K610i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
