Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Icemaker is not working on my whirlpool GS6SHEXNS00side by side refridgerator
My icemaker is not producing any ice at all. The water is still working. I changed the filter as needed and still no ice. I am forced to use ice trays. What else should I look for ?
northcarolinianfromny
  • Anonymous Aug 26, 2008
    I had the same problem--I live in an area with extremely hard water and have no filter---I dismantled the ice maker, cleaned it, put it back together and it appears to be working. The front cover (white module cover) snaps off--remove the 3 screws that hold the module in and remove the module(male end), it will be stiff but can be carefully pried off with a small to medium flat screwdriver. There are 3(three)---1/4 inch hex head screws that hold the ice maker in, 2 on the top into the side of the freezer, and 1 from under the ice maker--they aren't hard to find but it is best to use a regular length spin tight not a stubby to remove them. Remove the 2 phillips head screws that hold the "BLACK" section of the module to the ice maker and the spindle that rotates to move the cubes out of the ice maker into the ice bin will come out of the ice make and the plastic separator fingers will come off the ice maker too. Now that it is disassembled you can clean everything and reassemble. Mine had a small build up of 'white' residue that was apparently keeping the spindle from turning and removing the cubes to the bin. This is not a difficult repair and I'm sure it saved me a couple hundred bucks---what have you got to lose--it ain't workin' now so the worst that can happen is you gotta buy some more ice cube trays--LOL. If you have any questions shot me an email kf4sbs@aol.com
  • amccall497 Aug 26, 2008
    I have a Whirlpool side by side refrigerator. The icemaker has recently stopped working. The water fills the tray but the ice is not ejected at all. Any help would be appreciated.
I had the same problem--I live in an area with extremely hard water and have no filter---I dismantled the ice maker, cleaned it, put it back together and it appears to be working. The front cover (white module cover) snaps off--remove the 3 screws that hold the module in and remove the module(male end), it will be stiff but can be carefully pried off with a small to medium flat screwdriver. There are 3(three)---1/4 inch hex head screws that hold the ice maker in, 2 on the top into the side of the freezer, and 1 from under the ice maker--they aren't hard to find but it is best to use a regular length spin tight not a stubby to remove them. Remove the 2 phillips head screws that hold the "BLACK" section of the module to the ice maker and the spindle that rotates to move the cubes out of the ice maker into the ice bin will come out of the ice maker952467
and the plastic separator fingers will come off the ice maker too. Now that it is disassembled you can clean everything and reassemble. Mine had a small build up of 'white' residue that was apparently keeping the spindle from turning and removing the cubes to the bin. This is not a difficult repair and I'm sure it saved me a couple hundred bucks---what have you got to lose--it ain't workin' now so the worst that can happen is you gotta buy some more ice cube trays--LOL. If you have any questions shoot me an email kf4sbs@aol.com
Posted on Aug 26, 2008
Check to make sure the ice maker is not jammed. My refrigerator was only two months old when opposing plastic fingers on the ice maker jammed together. I'm not sure how it happened but I carefully straightened the bent finger and the ice machine started to work again.
PokeMeister
Posted on Jul 31, 2008
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
Ice maker not producing ice,already check the basic problems,
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker in refridgerator freezer won't make ice. It seems as if the water is going up into the freezer but no Ice is being produced. The ice tray has frozen ice in it, but it will not dump it in the ice...
Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
Oct 16, 2009 | Kenmore 50522 / 50524 Side by Side...
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
Whirlpool side by side refridgerator model GS6SHE*N*O, icemaker won't produce ice. Watter line is okay. This is only 6 months old.
make sure your ice maker is turned on and if it is a new install than it will take about 24 hours for the first bin of ice witch you will need o throw away because it is like the first snow the first ice that comes out will have the dirt and things that are in the line.filter and ice maker.
Aug 22, 2008 | Whirlpool Refrigerators
Ice maker not getting water
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
May 29, 2008 | Whirlpool GS5SHGXLS Side by Side...
Broken ice maker
Make sure icemaker cycles. If it is most likely bad water valve
Jan 05, 2008 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
254 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
