I have two amps in my car a 1100watt and a 800 watt both are almani.I have not had any problems with the system until now and I have had it for about a year.I have no sound what so ever from any speaker in my car.the music will come on for a couple of seconds and then fade out.I noticed on the 800 watt amp the green power light goes out and thats when the sound goes out as well.I thought it might be the fuses but if not does that mean the amp has gone bad?
  • 682 Answers
Make revision in fuses holder box and confirm that responsible fuses are firmly inserted-also confirm good connection of power lead(+&-) are connected firmly.
Posted on Jul 27, 2008
Can I use a 412 guitar cabinet in a vehicle as part of the stereo system at what type of amp what I use to push that
You would want an amp at least the wattage of the speakers, I would go double the wattage, say 800 watts and fuse speaker so as not to blow them. This way you have power to spare if you upgrade.
press the helpful button
INSANE Car Sound Systems
Custom Car Stereo Sound Systems
24 000 WATT Car Sound System PART 1 of 2
How To Design Car Audio System
Jan 23, 2016 | AMP Music
I have a 1100watt sub woofers, and a 1000 watt amp. Will the my sub woofers, or amp blow out or get damaged.
Are those rms wattage?
Anyways, your subs (if you have two) will double the power of your amp, meaning your amp will be under powering your subs. Nothing will get blown out but will never see their full potential. But if you were to use single sub with your amp then you are more likely see the full potential of the sub and amp.
2 subs=2200 watts is just twice the power of the amp output power!
Jan 06, 2011 | Car Audio & Video
I have 2 1100watt sony xplods will they run off a 1000 watt amp
yes it will work, but it will only put out the power to the sub that the amp allows, ie : 100 watt amp puts out 100 wats.
you can also try reconfigering your wire to your subs, if your amp is 1ohm stable and your subs you can come off the amp with a bridge and run subs in series or parralell, this will dramaticly improve the bass
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Amp issues
i myself would run a parallel bridged ciruit. basically run the speaker wires one positive on the right speaker side and one negative on the left side.
thanks
tom
Dec 23, 2008 | Car Audio & Video
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Amp getting really hot
well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
Disconnect the speaker wires and the RCA jacks from the amp.
If it still gets hot, the amp needs to be repaired.
If it doesn't get hot, check the impedance of the speakers and make sure they're wired properly.
If they are wired for the proper impedance, check each voice coil with an ohm meter to make sure none of the voice coils are shorted.
Apr 11, 2008 | Power Acoustik PS2-1600 Car Audio...
1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Jan 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
 Grubhead
Grubhead
