Question about Aurora Global AS702MX Shredder
Will not go forward
Hi..
I accidently put a mailing label from a plastic mailing bag through. It will go backwards not forward. I cleaned as much of the stuck label.. not sure how to take it apart or the best way to adress this. Can you help me?
thanks loads,Joanne Eldridge
  • jobug_2001 Jul 27, 2008
    thanks for this..I will attempt it and let you know how i proceed.
  • 797 Answers
Probably the gears or other parts are jammed with the plastic and sticky substance.
Make sure it is unplugged. Then see how to take some of the unit apart. Many of these kinds of units will be held together by screws in deep indentations. You will need a screwdrive of the type of the screw-head. Remove the screws and then you can split the unit apart and see what the problem is.
More than likely, it will be a matter of removing the sticky plastic jammed into the unit between the gears and or the rollers or other parts.
Posted on Jul 26, 2008
How do I replace the cable underneath the driver's seat to move the seat backwards/forward
On mine the the cable worked one rail an a spring worked the opposite rail .the lever that the spring worked was the problem and required unbolting the seat to clean and lube the levers on each rail with out making a mess. That was on an86 Ford.
I would suggest unbolting the seat an see if the cable is the full problem and alot easier then fixxing it in place.usually a bolt or nut in each corner.
Plastic garbage bags or card board to protect cloth seats an apair osaw horses or small table will make easier as well
Apr 22, 2016 | Seat Cars & Trucks
How can you freeze cooked beets?
throw them into ziploc bags or plastic tupperware type boxes and put into freezer - label with contents and date (once things freeze its hard to figure out what you froze if you don't label)
Aug 15, 2014 | Ice Cream Makers
What is the most common type of plastic used for making plastic bags?
polyethylene is by far the most commonly used plastic
Jan 13, 2013 | Retail Supplies
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
New lg gt540. insert sim card and it doesnt read it.
Hi There,
Here I have instructions Step-by-Step
1) Get the SIM and clean it with a clean and dry cloth.
2) Put the SIM facing forward in backwards.
3) Contact me if you need more help.
Yours Sincerely
Lewis
Apr 06, 2011 | LG GT540 Cell Phone
It wont go in reverse it only goes forward, the steering works fine
Hi
The ESC on this truck comes with a reverse lock out. The reason is that when you're racing, race requirements are that no reverse can be used. Now you may have accidently turned this on. Go to the Traxxas web site and download the ESC manual and follow the instructions for reverse lock out.
May 13, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
My vacuum goes backwards easily, but forward with GREAT effort..
I would look closely at the wheels; I suspect the rug let strings of material wrap around the axles, just inside the wheels. Get a knife in there to cut and remove the remnants.
Jan 20, 2018 | Hoover U6446-900 WindTunnel Bagged Upright...
Front air bag did not deploy on 1992 Buick Park Avenue
front air bags only go off when hit in front endthey go off at 15 miles a hour
Mar 11, 2009 | 1992 Buick Park Avenue
Aurora Global AS702MX Shredder Logo
254 people viewed this question
Top Aurora Global Office Equipment & Supplies Experts
chargerhp
chargerhp
Adorjani Laszlo
ray gallant
Are you an Aurora Global Office Equipment and Supply Expert? Answer questions, earn points and help others
