Question about Toshiba RDXS54 DVD Recorder/HDD Recorder
Toshiba RDXS54 ER7071
I've recently been having trouble with my Toshiba RDXS54 not reading any discs so I decided to attempt to clean the lens on the DVD drive (hoping it was a dirty lens & not a bad drive). After getting the lens cleaned & the device put all back together, I turn it on for the first time & on the LCD the unit gives me an error code 7071 (LCD says "ER7071"). I haven't really found a good explanation for this error code online. Nothing displays on the TV... the unit stops at this error code & I have yet to get past it. Do you know what the error is & how I can rectify it?
Thanks!!!
  • city_bhoy Oct 12, 2008
    I purchased the RD-XV45KB in October 2006 and it's been fine for two years. Now it tells me that all DVDs are ibvalid discs - including pre-recorded films.
    This could be a dirty lens but I'm not sure about opening the player up and cleaning the lens.
    Any advice on what the problem is and best way to resolve the problem ?
    I'm based in Herts , UK.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
2 Suggested Answers
SOURCE: ER7071
es liegt bei diesem fehler an dem dvdlaufwerk
bei mir war es ein loses kabel und eine blokade im dvdlaufwerk
nachdem ich es gesäubert hatte und wieder zud´sammengebaut läuft dvd-recorder ohne probleme
Posted on Oct 14, 2008
Bad disc?
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
I'm assuming that the symptoms (Bad disc) remain the same no matter what the disc's loaded to the unit.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the optical lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc, this is because of the movement of the optical lens back-and-forth. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the spindle motor - Check the spindle motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Jdvillanueva
Dec 17, 2011 | Toshiba XD-E500 DVD Player
The last week the DVD player isn't working. In some cases, it will spin the DVD (and I've tried multiple DVDs to be sure) and then display the error message "bad disc". Other times, it...
Hi kjones1021,
Assuming that the disc is good.
LINK1
LINK2
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 09, 2011 | Philips PD9012/37 DVD Player
I have a Toshiba SD7300 that will not read discs. the only response I get is "no disc". Is there an easy fix for this?
Hi Daniel,
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you have to clean it manually. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
LINK1
LINK2
Hope I helped you.
Have a nice day!
Jdvillanueva
Jul 19, 2011 | Toshiba SD7300 DVD Player
DVD PLAYER WILL DISPLAY "BAD"
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
LINK1
LINK2
Hope I helped you.
Have a nice day!
Jun 29, 2011 | Toshiba SD-K850
Have a Zenith DVD player insert a disc keepgetting disc error
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
LINK1
LINK2
Hope I helped you.
Have a nice day!
May 31, 2011 | Zenith Televison & Video
ER7071
Jul 26, 2008 | Toshiba RDXS54 DVD Recorder/HDD Recorder
"no disc" showing when disc is inserted.
The lens cleaners are nothing but litle brushes that more often than not make the situation worse. If you can get at teh lens, use a cotton swab and a little alcohol to clean it. If that does not resolve the problem, the optics are starting to fail. The message is generated after a number of attempts to read the Table Of Contents off of the disk.
Dan
Jul 10, 2008 | Televison & Video
Hello, Dustin / unsupported discs issue
Hi Brad
Before you attempt to purchase a new lens or a new unit, i would suggest that you buy a "Len Cleaner Disc" to clean your lens, if that doesn't help then you should either repair or buy a new lens.
To repair or install a new lens, you will need a service manual(Let me know if you need one.) Then you can do it yourself.
Please also remember that if you attempt to open or repair the player in anyway, it will void your warranty so i think you should take it to Panasonic and have the unit replaced or refunded.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Kind regards
Dustin Ellse (BearWeb)
Jul 03, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
DISCS
Lens could have attracted enough dust to keep from reading a clean signal. First try cleaning the lens. You will have to remove the cover. Dip a Q-Tip in Rubbing Alcohol and lightly squeeze out, then rub on the lens. See if this helps.
Apr 25, 2008 | Toshiba D-VR600
Toshiba RDXS54 DVD Recorder/HDD Recorder Logo
208 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
