Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Water line We found a houge coil of water line behind the two crisper drawers and wondered if that may be the reason our ice maker is not working properly
  • 218 Answers
That coil is the line to the water dispenser, and its purpose is to chill the water before dispensing it. The coil of tubing is better than a tank because it chills quickly, takes less space and doesn't hold stagnant water. It shouldn't have any effect on the icemaker.
Posted on Jul 27, 2008
KBFS20ECWH - On delivery, large coil of white tubing behind the two crispers. What is this?
it is most likely the water line. If you are not hooking it up to water, you can remove it.
May 18, 2015 | KitchenAid KBFS20ECWH Architect II...
My crisper drawers collect water
adjust your settings for what you keep in there...and you should be able to solve the problem
Oct 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Can I take the freezer door apart and wrap the water line with more insolation
No, you can't. The line goes into the mold of the machine with no access there.You have either an air leak in the dispenser area, around the ice shoot possibly, or the resevoir, which is located on the refrigerator side in the lower area behind the drawers is freezing, which is most likely the case. There are vents on the lower section for the crisper drawers. If you take out the drawers you'll find a roll of 1/4 " tubing which they call a resevoir that cools the water down. This is probably frozen,and you can insulate this, but I would raise the temperature in the fridge side or close the vents to the crisper area.
May 08, 2012 | Whirlpool ED2FHEXN Side by Side...
I have an ED2KHAXVS02 model and the ice maker works but no water out of the refrigerator. Any Ideals on how to fix the problem
Could be a bad water valve or the reservoir has froze. do you have things freezing in the crisper drawers?. If so try turning the temp down a little. The reservoir is behind the crispers.
Mar 21, 2011 | Whirlpool GS6NBEXR Side by Side...
The refrigerator always gets water in the base under the crisper drawers and on the shelves. How do I stop it from doing this?
There are two reasons. One check defrost is working properly. And second defrost tray has no crack.
and also while inserting defrost tray 100% pushed in.
Jan 22, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Dec 13, 2008 | Refrigerators
Water volume slow
You can add more line to the coil. Do not impede the air flow or the ability to close the drawer. Not a factory recommended action though.
Dec 03, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
The Ice Machine is working but the water is not flowing
there is a water tank situatet behind the salad crisper ( drawer) if is iced up reduce the temperature on your thermostat the line then goes under the cabinet if you take the kickplate off you might be able to see it and then attaches under the freezer door towards the bottom hinge. Personally I think that the inlet water valve is gone they have a duble valve one feeds the ice maker and the other the water supply it can only be replaced as a whole unit.
Nov 02, 2008 | Samsung RS2630SH Side by Side Refrigerator
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
106 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
