Question about Storkcraft Baby Rochester Crib
Side rail I can't figure out how to slide it up and down
It is kind of hard. I use my foot. Push in on the bottom of the rail with your foot as you push down on the top. It has to unlatch on each side. Sometimes you have to giggle it.
Posted on Jan 09, 2009
Mislaid assembly instructions trying to get a email copy if possible for "Adam Cot Bed"
Here you go: http://www.babystyle.co.uk/pdf/CalgaryCotbed_AI.pdf
May 24, 2011 | Toys
Can remove the front passenger seat of a 2003 Honda Odyssey? How?
Your seat is bolted down. slide the seat all the way back as far as it will go, and look at the slide rails( tracks that the seat travels on), you will see 2 bolts. going into the floor on the rails. just undo the 2 bolts, and then slide the seat forward(slowly, the front has no bolts holding it), on the back side of the rails, are 2 more bolts. Remove thise bolts, and you should be able to remove the seat. (This is a manual seat, not a power seat) hope this helps, please rate helpful or not
Jan 29, 2011 | 2006 Honda Odyssey
Instruction book for Arrow ETF50P staple gun . lost the instructions and can't figure out how to insert the staples in the gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Apr 19, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
How to convert to daybed?
I am not sure if you have solved your problem yet, but all you have to do is slide the front side of the crib off the hinges. The rail that slides up and down, will come all the way off, turning it into a daybed.
I haven't been able to find my instructions either, so I figured that much out. Now I am trying to figure out how to convert it to a regular size bed. :- (
Good luck to you!
Jan 02, 2010 | Storkcraft Baby Aspen Stages Crib
My fisher and parkel dishwasher keeps displaying F1
The best thing to do is turn the power off ,remove the bottom drawer by pushing in the clips on side of the drawer ,just below the round plugs. The clips are attached to runners, push them back to release the drawer and ( after taking out the rack and spray arm) put the drawer on its r.h.side. Mop up the all water in the base, then remove the cover that goes over the back L.h. corner, this will expose the mains/flood switch board ( make sure you dry the roof of the drawer before you take the cover off , or water can drip onto the board .....not a good thing!!!yikes.gif).
To remove the cover, push in the clip in the middle front edge of the cover with a flat blade screwdriverand slide the cover foward a bit, then put the screwdriver under the clip and twist up, the cover should now pull off to the right. Spend a couple of minutes drying the board with a hair dryer and mop up any remaining water ( be careful of the board again). Refit the cover and switch back on ( you shouldn't need to force the cover on, just slide it on from right to left , but you may have to push down the cover just above the clip to get it to lock once it is located correctly). If it doesn't F1 again ,all good, if it does , remove cover and redry, and repeat until it doesn't.
To refit drawer, slide out L.h. rail and sit drawer on it, then lift right side of drawer and slide out other rail and sit other side down. If the rails don't want to slide foward and lock, lift the drawer at the front while sliding the rail fowarduntil the front edge of the rail is just at the clipping gap at the side of the drawer, then make sure the drawer is sitting down firmly on the rails and pull clips foward to lock. If the drawer has been clipped in correctly it will slide in and out nicely, if not , look at the back edge of the drawer when it is fully open to see where it is sitting too high and rectify by refitting the rail on the affected side/sides. By this point if any part of the bottom drawer was broken ,you would have seen it. Also check the top drawer by releasing it and pulling it foward,shine torch in and have a good look.
Hopefully it won't leak again unless ther is a faulty part not visible to the nakedshock.gif eye, check by running one drawer for a couple of minutes, stop the cycle and open the drawer and check the outsides for water ( don't be too worried if you see water in the bottom between the drawers as it will drip from the roof, unless the drain or fill hoses are split ) ,if ok, run the other drawer and check.
Remember, if you get to a point where you don't feel confident with what you doing or you think you might break something, leave it and call a professional to do the job, you may save money in the long run and if you going to expose wires or connections always switch off and unplug before removing the cover, you dont know whats underneathxbones.gif.
Nov 14, 2009 | Dishwashers
Sorelle Allessandra Crib - broken plastic slide in side rail
Products America can not provide parts for the Sorelle cribs however they should be able to provide you with contact information for the company. You can call 800-205-9642 or 800-772-1041 and speak with a customer service rep who would be more than happy to assist you in contacting the company.
Jun 17, 2009 | Graco Ultra Deluxe 5-in-1 4605 Crib
Can not get side of crib to come down!
You pull up and push in with you knee on the lower part at the same time.
Feb 28, 2009 | Storkcraft Baby Aspen Stages Crib
Flood switch
I had the same problem and I fixed mine. It wasn't hard at all. First, make sure power is off either unplug or shut off breaker. Next, open the lower drawer and on the sides toward the bottom you will see a circular recessed pin with a flat slot. Without forcing, wiggle the door down. When you get it off you have to remove the wire harness, just unplug it. Now, on the sides at the bottom, you will see where the drawer fits on the slid rail. Push the plastic button slightly to release the lock for the slid rail to the drawer and push the slid rail all the way back as to release the drawer fronm the rail. Be carefull when you release one side as to hold it up still while removing the other one. Now, flip the drawer on its side and try to get it as far out of the way as possible to the right of the unit. You will now notice a plastic cover at the back left of the unit. This is where the flood swith is. Remove this cover by sliding to the right. The will be water under the circuit board you see. Soak up as much as possible and you can use a hair dryer to get the tough spots. Now try to find the resson for the water. I had a mouse living under mine. Look for a break in one of the hoses. After all dried up turn power back in before reinstalling lower drawer. If dried properly, the dishwasher should stop beep beep beeping. Now turn water back on and run upper drawer. Inspect hoses again. 50/50 chance. If now water, reinstall lower by replacing plastic cover, place drawer on rails and slide all the way back. It should click back in if on rails correctly. Now install the door face, line up tabs into drawer, and slide up. Align holes for recessed circular pins and just push them in. Test lower. Thats all I got, Hope it helps.
Oct 03, 2008 | KitchenAid 23 in. KUDD01DPPA Stainless...
Trying to take my cd drive out and put in a new one but the old one will not slide out and I do not see any screw that need to be removed
If it is a normal PC, there should be 2 screws on either side of the drive that have to be removed before the drive can come out. Many times you have to remove both sides of the computer case to get to these.
This can vary however from manufacturer to manufacturer. Some put the drives on what are called rails where, if you release the rail it will simply slide out, other times only one side has screws.
If it is a mass manufactured PC (DELL, Gateway, HP, etc.) you should be able to find a manual on their site that would help.
Sep 21, 2008 | Acer Computers & Internet
Side rails
I have a similar problem, but a different Simmons crib. I called the company that momof4girls unrecommended and they were VERY helpful, but they were not able to ship me the parts as Simmons discontinued this type of hardware in the early 90's. My crib has a headboard and footboard - the 2 side boards are able to slide up and down on aluminum slats (almost 3 feet long.) The aluminum slats are connected to the headboards with 8 bolts; what I needed to order replacements of are the plastic sliders that allow the sidewalls to go up and down on the aluminum bracket. Not only do they allow it to go up and down, but without them you are not able to assemble the sidewalls to the crib at all. I solved the issue buy purchasing L brackets at Lowes and permanently attaching the sidewalls to the headboard and footboard, but it made it so the sidewalls did not raise or lower. I am ok with that! However, if you do NOT have the aluminum slats, you may be out of luck. The spring for the bed attaches on the aluminum brackets, so even if you were able to bolt the 4 sides together, you still have to figure out a way to attach the spring for the mattress (which connects by sliding a hook into holes on the aluminum bracket... no room for bolts here.) I am rather surprised that the hardware for this crib is plastic and aluminum; the bed is HEAVY and it is very difficult to put together as the aluminum slider is easily bent and the plastic sliders are flimsy. I actually broke the plastic pieces during assembly. No wonder this hardware was discontinued! I called Simmons and asked if they had an "updating' kit... they do not. Good luck!
Aug 25, 2008 | Bassett Baby Gear
Storkcraft Baby Rochester Crib Logo
162 people viewed this question
Top Storkcraft Baby Baby Gear Experts
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Storkcraft Baby Baby Gear Expert? Answer questions, earn points and help others
