Yamaha RX-V757 Receiver
I have speakers wired throughout the house into a connection box which is operated through Zone 2. The circuit breaker tripped and I rest but Zone 2 won't work. When I tried to adjust Zone 2 volume, the receiver displays "FIX".
No prior posts have worked. I am so frustrated. Has anyone had this experience?
  • 682 Answers
I thinck that you have internal short circuit in wiring of zone 2. and you must fix this wiring first befor you go ahead -or you disable it by disconnecting it-and the rest of the system will work fine.
Posted on Jul 27, 2008
Yamaha rx v757 av receiver
tape out to line in on eq, line out from eq to tape in on receiver, use tape monitor switch to make eq work
Mar 14, 2014 | Audio Players & Recorders
Subwoofer output issue 5.1 setup. 2 speakers
Try turning up the sub out-put, in the Receiver settings
Sep 11, 2013 | Yamaha RX-V757 Receiver
Smoke started to come out of top of RX-V490 receiver, and now sounds a little more distorted than usual. Is the receiver salvagable, I know I triggered the protection circuit, but will it keep happening? I...
It all depends how much the amplifier circuit was damaged and how much you now push the system. It could be worth opening the unit and checking for any obvious damaged to components before you go any further.
As you've stated you want to run 4 speakers I take it you're not using the full 5.1 System.
If this is the case then the best/easiest option for running 2 sets of speakers is to get 2 Pairs of 4 Ohm Speakers and just connect them in Parallel to the Front Output which is rated at 70W + 70W (8Ohms).
If you need any further assistance of clarification just ask.
Please leave feedback
Cheers
Andy
May 11, 2011 | Yamaha RX-V490 Receiver
Can a yamaha ipod dock connect to an rx-v757 receiver?
You can connect him true the auxiliary inputs with an adaptor cable 3.5mm to rca
Jun 02, 2010 | Yamaha RX-V757 Receiver
Yamaha RX-V757: Tuner not working
Is it set for XM / Sirius? If so, you need their special antennae unit; or are you talking AM & FM?
Jan 12, 2010 | Yamaha RX-V757 Receiver
Right speaker dead on zone 2 on my RX-V 1600 receiver
must be the right speaker wire, sounds to easy I know but maybe your wiring is grounding out the audio to that channel.
Jul 15, 2009 | Yamaha RX-V661 Receiver
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
Yamaha RX-V757
make sure you have not wired from box to speaker then to another speaker ,you should wire from switch box to one speaker then from box to another speaker, this presents the right load to the amp, if you have done this you may have a faulty switch box.
hope this helps.
cable guy.
Jun 20, 2008 | Audio Players & Recorders
The receiver shuts down when zone 2 is turned on
Disconnect the speakers on Zone 2 and try to turn on the receiver again. If the receiver works, there is a shorted speaker wire, pinched wire, or a blown speaker on zone 2. Good Luck
Jul 01, 2007 | Yamaha RX-V657 Receiver
127 people viewed this question
 Grubhead
Grubhead
