Question about Faberware FCP412 Coffee Maker
Faberware Fcp412 Coffee Maker
Buy repalcement part: thermistor device
  • 33 Answers
SOURCE: Black & decker glass thermos coffee maker
try this
http://www.abtecparts.com/black_n_decker.htm
Try this to order all of your part needs
Please don’t forget to rate me!
Posted on Feb 16, 2009
  • 14 Answers
SOURCE: We have a Faberware super fast fully automatic
If the power cord can be removed via a plug on the unit you should test the power cord for continuity. This can be done with an inexpensive multimeter. The cord should be removed from the coffe maker and the wall outlet. Then connect one of the probes on the meter to one of the prongs that go into the wall. The other probe of the meter should be touched into one of the two holes in the other end of the plug. You should set your meter to read resistance or ohms. If the meter reads close to zero then one leg of the cable is fine. If it blinks a "1" that usally indicates an open connection on a digital multimeter. If that is the case then connect the probe to the other prong. Once this is done then you need to test the other prong.
Hope this make sense.
If you get continuity on both legs of the power cord then I can explain further how to test the coil in the coffee pot itself.
Bob Janelli
Posted on Oct 01, 2009
Testimonial: "thanks for the help, I'll do the testing and let you know what happens."
SOURCE: Faberware Superfast FCP412 makes weak coffee
check the bottom of the tube that holds the coffee basket....there is a "washer like" piece on the bottom. Make sure it is clean and moves freely, or the coffee won't percolate properly. I had the same problem and that fixed it
Posted on Mar 16, 2010
  • 176 Answers
SOURCE: Need relacement cord for Faberware coffee
Hi. If you have a pot that calls for a 3 wire cord, you are almost out of luck. You can not buy one. The only cord that will fit , (if it is adjusted) is the same cord that you have on your PC, everything fits but you have to dig a little trench on the part that goes into the pot Take a good long look at the part that goes into the pot and you will see what has to be done. Good luck. bobbyone
Posted on Aug 11, 2010
  • 176 Answers
SOURCE: Faberware FSU-122 coffee maker does not perk
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers
I need instructions on how to use this coffee maker: how much ground coffee to put in, how much water?
Hi. Start with 2 scoops for every 4 cups of coffee, Then adjust from there, until you get the taste that you like.
Jul 24, 2010 | Faberware FCP412 Coffee Maker
Looking for Farberware Model 142B 12 cup coffee maker paper filters and manual
Hi.For filters go to eBay and search for Farberware coffee pot parts. For manual email callahanronald@att.net. Good luck Ron
Jan 13, 2010 | Faberware FCP412 12-Cup Coffee Maker
Need relacement cord for Faberware coffee maker FCP280A. What replacement cord should I buy? (3 foot)
Jan 01, 2010 | Faberware FCP412 Coffee Maker
Looking for a replacement handle for a FCP412
Go to my eBay auction. look for Farberware coffee pot parts. They are use but you cannot buy a new one (Ron622c) Good luck. bobbyone
Dec 26, 2009 | Faberware FCP412 Coffee Maker
Have a FCP412-AG the lead to the heating element with the diode is bad, any replacement or can we wire around it.
Hi. You have a 12 cup China.The heating element is broken. On the China poy you have to replace the body of the pot because the heating element is weilded to the pot. I sell the body for 8.00 plus S/H 3.00. Good luck bobbyone callahanronald@att.net
Oct 27, 2009 | Faberware FCP412 Coffee Maker
Cleaning my Faberware coffee maker
BRASSO, VINEGAR AND WATER OR C.L.R. ONE OF THIS MIGTH WORK
Oct 02, 2008 | Faberware FCP412 Coffee Maker
Week coffee
I did replace the thermistor and it did fix the problem. However, you can't get the exact replacement, so I had to "McGyver" it to make it fit. The product is made by Therm-o-disc. The master supplier is Stancor. Newark distributes the Stancor thermistor. I bought the 160 and 170 degree ones, went with the 170 degree one.
Aug 26, 2006 | Faberware FCP412 Coffee Maker
Faberware FCP412 Coffee Maker Logo
95 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
