Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
GE GSH25JST Icemaker
My Icemaker is not making as much ice as it used to. The refrigerator was bought in 2006. Any thoughts on the problem and how to fix?
Thanks,
Rob
  • 183 Answers
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Posted on Aug 23, 2007
  • 109 Answers
SOURCE: ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Posted on Mar 28, 2008
SOURCE: ge monogram zd115c automatic icemaker not making ice
Unfortunately, this has been a regular problem with mine for 6 years.  It started within the first week of installation.  I suggest calling GE and keeping track of when you called, who you spoke to, etc.  Every single part has been replaced at lest once and I am still without reliable ice.  I have been asking or a replacement since day one.  GE is not good on the customer service end of things.
Posted on Sep 15, 2008
  • 531 Answers
SOURCE: THe ice maker has stopped working in my GE refrigerator.
change icemaker
Posted on Apr 06, 2009
Karthik316
  • 187 Answers
SOURCE: GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Posted on Jul 25, 2009
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded ยท How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Bought house with frig in it not used for a while fridge works fine turned on water for ice maker water works does't make ice
    Is icemaker switch and light on? If so check for plugged fill tube. If not, the water valve or icemaker will need replacing.
    Sep 25, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
    Interface board does not work. We bought a new
    We need to trace the wiring when ready, Sea Breeze
    Mar 20, 2010 | GE Refrigerators
    Icemaker not making ice
    Sounds like you need to replace the ice maker. The mold heater appears to be defective.The mold heats up prior to a ice dump. I donot believe it is worth repairing
    Sep 29, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
    Icemaker
    Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
    thumbs up
    Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    I have a PSS26 ge profile fridge and it quit making ice
    The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
    Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ice maker in door not making ice
    make sure the switch is turned on on the icemaker if it is then see if there is water in the icemaker it could be either water valve or icemaker
    Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ice dispenser
    I bought the PSS26MSWSS model (GE Profile) in August 2007. I have had numerous problems with the icemaker. It was out of warranty for the last two visits (Oct 2008) but GE warranteed anyway because of the previous problems I had had with the icemaker.
    The last time the repairman came out I asked him if this latest part would "fix" the problem. He said it would help it but not fix it because there was a design flaw with the back/rear dispensing icemakers. I paid around $2,000 for this frig. I called Lowe's and told them of the problem and they said they would replace the refrigator for one of equal value.
    Other than the problems with the icemaker I thought this was a very nice refrigator. However, I don't think I will buy another GE. If they knew there was a design flaw they shouldn't have sold these refrigators or had a recall when they became aware of it.
    Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Noisy refrigeration without a icemaker.
    Lift the arm up on the icemaker to shut it off some models have a switch on the side of the ice maker you can turn off as well a green indcator light
    May 10, 2008 | Refrigerators
    GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
    76 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    RepairNinja
    RepairNinja
