Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Stopped printing black
Tried 2 new cartridges, cleaned heads, but that did not solve the issue. This is exactly the same problem Joe Donovan had, but we prefer not to use his solution of throwing out the printer. Color prints fine.
  • freddiegirl Jul 26, 2008
    My copies and pictures are poor quality. Look mostly yellow/green with streaking. Still have ink in the cartridges. I have calibrated it, cleaned the printer head, and hit the button for original settings.
  • teomawork Jul 31, 2008
    Exactly the same problem. Won't print black after repeated printhead cleaning and calibration and tried 3 new cartridges.
When I realized there is a charge for the FixYa services, I decided to contact Kodak directly. I am so GLAD I did. They were able to walk me through what needed to be done to correct the problem. Their service was timely, polite, and FREE! I suggest if anyone has the same issue, contact Kodak directly. Their customer service exceeded our expectations and I'm sure it will do the same for you.
To FixYa,
You may want to let people know up front that there is a charge. That way they can determine if they want to provide you with their personal contact information. I know that I NEVER would have signed up if I had know of the charges in advance. Because of that, I ask that you remove my information from your records.
Hope this helps someone else in the future.
Posted on Jul 27, 2008
My HP 6500 wont print black ink. It's like a very very light grey and I can't see it. Tried 2 new print cartridges and no luck. Please help.
The HP 6500 printer has separate in cart and print heads. The light print you are getting is because the print head in clogged with dry ink. First thing to try is to go into the printer software on your computer and do a print head cleaning procedure, this will take a few minutes to finish. You may have to run this several times to clear out the dry ink. If this does not solve the problem when you will need to get a replacement print head, the part number is CB868-30002
Sep 25, 2012 | HP Officejet 6500 Wireless All-in-One...
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
Incompatible print cartridge
If you purchased the cartidge recently (30 days or less), then just bring it back to the store and tell the associates that it simply stopped working, they may be able to exchange it for you.
If not, you will probably need a new cartidge. The good thing about HP cartidges is that the print head (which is probably your problem) is built in, so issues are usually solved by just buying a new one. This, of course, means you have been replacing your print head every time you run out of ink, which adds up quickly in costs; but thats another subject
Hope that helps, Good Luck!
Aug 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP J5680 is printing and scanning vertical gray stripes
The fix is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=za&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 16, 2009 | HP Officejet J5780 All-In-One InkJet...
Canon iP90 stopped printing in BLACK
hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
thank u!!
Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
New cartridge won't print
  1. Make sure you removed the tape from the ink cartridge.
  2. Press the <Menu> button on the printers operation panel.
  3. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
  4. Press the <Set> button.
  5. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  6. Press <Set>.
  7. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
Thanks, Joe
Nov 26, 2008 | Canon MultiPASS F80 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
Dec 19, 2007 | HP Photosmart C6180 All-In-One InkJet...
Black not printing
I just ran into a similar issue with my MP390. Actually both the color and black inks were not printing very well. I would get very inconsistent printing. Fixed the problem very easily and quickly as follows: On the top of each print cartridge, there is a small hole. Remove the print head (lift the gray bar at the front of the print head and lift out the print head) with the cartridges still in place. Holding the print head over a piece of paper/paper towel, blow into the holes on the top of the cartridges (either directly or using a straw/tube of some kind). You should get ink coming out of the botton of the print head, both color and black. Replace and print head and test print.
Feb 28, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
