> I received no CD's when I purchased ... would like to build a Recovery CD.
If OFFICE MAX won't supply a CD, or give you any other technical support, as part of the "warranty" that they offered when you purchased the computer, you might be able to telephone the manufacturer of the PC, and order a set of "System Restore" CD/DVD disks.
Or, if your computer still is running Windows, there should a utility program that you can run, in order to "burn" your own set of "System Restore" disks.
> it has stopped booting ...
Totally?
When you first turn it on, do you see any message like "Press <BLAH> to change boot-order" or "Press <BLAH> to run System Recovery" ? If so, then press the <BLAH> key, to see if your computer has a "hidden" area that can be used to "restore" your computer to its "factory" settings.
You could always use Ubuntu either temporarily or permanently. It's an Operating System based on GNU/Linux and is completely free, and in a lot of people's opinions it's better than Windows. You can set it up to run on a seperate partition and choose which OS to run at boot, or you can format the drive and just install Ubuntu which will automatically run at boot.
check it out here: What is Ubuntu? Read about it, get the free download, burn it to a CD-R and reboot to install. The installation is straight forward, and the new GUI in 9.10 is simple to learn for a new user. Most drivers are automatically configured if not all, already. :) Hope it helps
One thing that can cause a failed CD burn is the IMG file in a user's temp file.
Left click Start - Left click Run
Type %temp% and hit enter
Find a file that will have img_1 on it
This is the file that windows uses to burn files on your CD - it acts like an image place holder. Right click on it and delete that and see if that resolves the issue
Hello, No you can't reinstall it again cause the moment you install the nob you are required to run your installer cd or files then if you don't have the installer cd or files how can you run the installation process. My recommendation is that let the nob try to scan all parts of your system then read its comments from nob after it finished scanning all your files in the system. Then fix the area where nob is try to locate the potential threat located. Also you can reconfigure the nob settings to give you a customable security system in your own custom settings.
Whenever you connect a new peripheral to your pc it detects it and tells you that it has detected a new hardware and tries to install necessary driver files for it. If your OS is not having necessary files it asks you to insert the drivr CD. In order to let the OS know what is configuration of the H/W .ini file is required which remains in the driver installation CD. You have to show the path to the OS where the .ini file is located. If the PC does not detects the camera on Plug n play then you can go to control panel camera and scanners and add a new one over there once asked for driver you have to give it a path to the installation CD. Now a days vendors do not give away open drivers they put it in autoexe cab under this situation you should not connect the camera to the PC untill you run the exe or setup file in the installation CD after running it you can connect the camera and windows will detect it. Hope this solves your prob. If any further assistance required kindly ask.
In the disk you should find a setup file or .exe file to install the game, the autorun file is just to tell the PC to run the file. Have a look for it If you cannot find it please post back.
You're probably going to have to set up an ActiveSync connection between your PC and your 2415, then run the program installer on your PC while you're connected to the iPaq.
