Question about Lexmark X1270 All-In-One InkJet Printer
I got a new computer and i can not get my printer and scanner to work.
Hi mate, have you installed the cd given with the printer..???
If no, then you have to install the software given in the cd.
If yes, yes then try to fix all the cords again, may be there is a loose connection, or first uninstall and re-install the software given in the cd.
Posted on Jul 28, 2008
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
I installed a printer on my PC and the scanner does not work. Should i install the scanner aswell?
Do you have the combo printer that comes with scanner and printer in one machine? If you do, then one installation should work the device as the computer will recognize it as one. If that's what you have, and the scanner still doesn't work, return the machine and ask for a new one.
If you have separate scanner and printer machines, then you should have two installation discs as each should have its own. You will need to install the scanner if this is the case.
Hope this helps.
Aug 30, 2011 | Office Equipment & Supplies
Updated from xp service pack 3 to windows 7 o/s. Scanner is not recognised, need a driver for it to work with new o/s. Canon canoscan N65OU.
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device
hope this helps
Apr 19, 2011 | Computers & Internet
Connecting old IBM color flatbed scanner to new computer
Not likely to work reliably if you get it to work.
The parallel port must be set to communicate in both directions. The SUB to Parallel adapter may be a ONE-WAY communications device.
Get a new (or used) Epson scanner or Epson all-in-one ($50) which includes a scanner and printer! Your new computer may not have the proper drivers for your old IBM scanner, anyway. If you purchase an Epson all-in-one, get a "WorkForce" model - that's their latest product line.
Sep 28, 2009 | IBM Color Scanner Flatbed Scanner
Printer and coper work scanner does not with the new vista. Can it work with vista
Click Here and Follow the Step by step instruction.
Hope this help. Please Rate My Response! Thanks!
PREM
Apr 21, 2009 | HP PSC 2210 All-In-One InkJet Printer
Have just installed talktalk to my new laptop, the printer is working fine,the scanner is not working, i can not find the installiation disc,it is an HP officejet 5610 all in one.
Have just installed talktalk to my new computer, the printer is working fine,the scanner is not working, i can not find the installiation disc,it is an HP PSC 1410 all in one.
Oct 28, 2008 | HP Office Equipment & Supplies
Scanner
Was your old computer XP and the new one Vista?
Dec 28, 2007 | Lexmark X2250 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
