Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher and Paykel
Hi, I have a problem with the second draw of my double draw dishwasher, where it tries to start up by ends with a F2 error after a few seconds. Can you please send me (bbang01@gmail.com) the service manual. Thank you.
  • charlesmke Nov 12, 2008
    I have the same problem. The second draw of my double draw dishwasher tries to start upby ends with clicking noise and a F2 error. Can you please send me (charlesmke@yahoo.com) the service manual. Thank you.
    Charles
  • 770 Answers
Check your email
Posted on Jul 30, 2008
On the 2nd draw will start washing but not even a minute flashes the F2 error and stop washing, what this means?
Hi Francesca, The link below is a short youtube video on how to simply fix f2 on your fisher and paykel dishwasher.......CHEERS..
https://www.youtube.com/watch?v=qP_X9iG0f-g
Mar 29, 2016 | Fisher and Paykel Dishwashers
How do I find out if my warranty is still good.
Firstly open the top draw and on the left hand side between the two draws there is a plate with the model number and you dishwashers serial number .
Once you have that info you can either go on the Fisher and Paykel web site or ring your local distribution or service agent
Cheers I hope this helps
Aug 16, 2014 | Fisher Paykel DD24DCW7 | Double Dishwasher...
Errors and restarts
will need a description of the problem. Some of the common fault codes are F1, F2 and F3.
All these fault codes stop the dishwasher and will not go away until the cause is removed. Please indicate the problem you are experiencing.
Jan 02, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
Fisher and paykel double dish draw has stopped working and is coming up with F5
Hi.
F5 is Lid Fault.
Try clearing the error code by disconnecting power from circuit breaker for five minutes. If that does not help, then there is a problem with lid switch. The part must be tested and replaced.
Regards.
Ginko
Aug 20, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
About one minute after pressing start, all stops and F2 flashes. Need a solution before tearing into it.
Please provide model no. of your fisher and paykel dishwasher.
The F2 error usually means the rotor at the base of the dishwasher is either faulty or is unable to move due to food particles getting caught.
Happy to help further if you can provide model no. and if double drawer then in which drawer this is happening?
Aug 17, 2010 | Fisher and Paykel Dishwashers
HI I HAVE A F2 CODE ON MY TOP DRAW OF MY DELONGHI DOUBLE DRAW
You will need.to remove the draws and dry the under tray as it has a flood.warning sensor to detect water, this is due to lime.building up.around the tub top.seal and will.need.cleaning off as it causes leaks to run down into the tray
May 12, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fault with my dischwasher
F2 indicates the motor is not rotating.The motor may be jammed or defective. Also , the motor rotation sensor may be defective
Jun 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
137 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
