Question about E-Machines eMachines Desktop PC
Vertical lines in video
I have recently done something to my computer to cause vertical lines to appear when playing video files. Also lines appear on the boot screen. Any suggestions? Thanks
  • 981 Answers
It sounds like you installed a video codec or driver which isn't compatible with your other codecs or drivers.  If you replace them both, you'll be covered, won't you?
Posted on Jul 27, 2008
What cause Vertical lines on my Toshiba TV Model 46G310U that affect the way the image is seen. Also some white bands Horizontally are appearing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | Toshiba Televison & Video
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
Just recently the monitor started experiencing a faded screen and vertical lines1/8" spaced across the screen. A remote controller took over my computer and saw what i saw and mentioned something...
Greetings,
You can double check the suggestion of the vidoe card by connecting your computer to another monitor. If the lines appear on the second monitor then the diagnosis is correct and the video card in your computer is failing. If the lines do not appear in the second monitor, then your monitor's screen is failing and you'll need a new monitor.
Regards,
Selk
Nov 16, 2010 | Gateway HD2200 LCD Monitor
Hi, i have AL1716 monitor (2 year old). Recently, there is a blue vertical line which appears on and off sometimes in the monitor. Can anyone suggest on a solution
Is the vertical line always at one location ? (on the screen)
If so, it appears that the video card/driver (on your PC or laptop) may be causing the line to appear occasionally ... i.e. flaky ... and it will likely fail (completely) in due time. To confirm it's the video card, try using another monitor (long enough) to see if it happens.
[ The line may also be caused by "dead" pixel on the screen ... but this usually happens on randomly located pixels on the screen, not on one vertical line. But, it may also be a possibility ... in which case, using a different monitor may prove it one way or the other ]
Aug 11, 2010 | Computers & Internet
3-4" thick vertical line on 42" sanyo plasma tv
its most likly caused by either vert controler along bottom of set or ribbon to that part of the controler if you heard a hissing sound most likly is the controler itself
Jan 28, 2010 | LG 42PC3D 42 in. Plasma Television
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Vertical lines on canon a95
Go to www.digitalcamrepair.com then click on the self diagnosis page. for your answer to your question.
May 28, 2008 | Canon PowerShot SD1000 Digital Camera
Red vertical lines appear, can only run computer in Safe Mode
check the video cable and see if it;s properly seated. run the laptop with something that uses memory. if the video chip it going to show signs of problems, it will be more prominent when the laptop gets hot. most cases laptop motherboards have integrated video cards and cannot be replaced.
Aug 27, 2007 | Dell Latitude C640 Notebook
Line across top of screen
If the picture is ok otherwise then only thing that probably needs to be done is a vertical height adjustment. That is if the lines never changes position from cold to hot.
Feb 27, 2007 | Sony FD Trinitron WEGA KV-32FS16 32" TV
E-Machines eMachines Desktop PC Logo
55 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
